Intel® oneAPI HPC Toolkit
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
print mpi rank on stdout
Ben_Foster
When running an f90/mpi code, I would like to prefix all lines written to stdout with the rank of the mpi task, so after completion, I can sort all stdout to separate files for each mpi task. The AIX/xlf90 compiler with IBM MPI lib has an env var to do this, is this possible w/ ifort + Intel MPI? Thanks,
Gergana_S_Intel
Hi Ben,
You can use the -l mpirun option just for that purpose. Here is an excerpt from our Reference Manual:
-l
Use this option to insert the MPI process rank at the beginning of all lines written to the standard output.
I'm not sure the font here is clear but this is the letter "l" (as in line), and not the number 1.
Let us know if this helps.
~Gergana
Ben_Foster
Wow, that was easy, works great! Thanks a lot Gergana, your quick response is greatly appreciated!
--Ben
Gergana_S_Intel
Glad it helped :)
~Gergana
