Intel® oneAPI HPC Toolkit
support for Fortran USE MPI_F08 on Windows OS
DataScientist
Valued Contributor I
Does Intel 19 cluster edition for Windows support the use of USE MPI_F08 in Fortran applications? When I try to compile code with this module on Windows with Intel 19.4 compilers, I get the following error:
error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [MPI_F08]
        use mpi_f08
compilation aborted
I have,
mpifc.bat for the Intel(R) MPI Library 2019 Update 4 for Windows*
Copyright 2007-2019 Intel Corporation.
Frank_Illenseer
There is another long existing tpoic about this without any comment / solution ... https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/779429
Frank_Illenseer
[ Original thread where this question was posted: https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/820704 ]
DataScientist
If this question had been asked on the Intel Fortran forum, it would have had several responses and possibly tens of commentaries for improvements in a matter of an hour. It's sad to see this community is so dormant or at best, so adamant about MPI Fortran.
James_T_Intel
I apologize that this thread was previously missed.  Our development team will be adding the Fortran 2008 modules in Intel® MPI Library for Windows*.
SC2
Hi, Is there any update on this thread? Thanks!
