Intel® oneAPI IoT Toolkit
Get answers to your questions about bringing big data technology and IoT to healthcare, smart homes, aerospace, security, and more.
VxWorks 7.0 Integration
omer_navruz
I am trying to use the tools provided by oneAPI, such as V-Tune Profiler, to analyze the performance of a downloadable kernel module running on a target system with VxWorks, written in Workbench or Eclipse (I can use both).
I have installed the base kit successfully, I can currently use the tools integrated with Visual Studio 2019.
I have gone through all the documentation under my installation directory, and checked out the online documents, but I could not find any clues. Is there any integration guide for VxWorks?
Thanks in advance.
Rahila_T_Intel
Intel® VTune™ Profiler is not supported in VxWorks.
You can find supported Operating systems, system requirements and other information regarding Intel VTune profiler in the below link
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
If you are interested to do performance analysis using Intel VTune™ Profiler, you can refer the given cookbook.
https://www.intel.com/content/www/us/en/develop/documentation/vtune-cookbook/top.html
This Cookbook introduces methodologies and use-case recipes to analyze the performance of your code with VTune Profiler, a tool that helps you identify ineffective algorithm and hardware usage and provides tuning advice.
omer_navruz
Thanks for your reply.
Actually, I do not have to use VTune Profiler. I am just trying to do an analysis on a downloadable kernel module running on VxWorks, using oneAPI tools. It can be Intel System Debugger, Intel Inspector, etc. I am pretty sure that VxWorks is supported by system debugger, but still, I could not find any information about integration in the documentations.
Are there any documentations regarding using oneAPI tools on VxWorks? Thanks.
