Intel® oneAPI IoT Toolkit
Get answers to your questions about bringing big data technology and IoT to healthcare, smart homes, aerospace, security, and more.
Intel® oneAPI IoT toolkit will no longer be available as of version 2024.0. However, the components that were included in this toolkit are still available for download and use. For information about these tools and how to access them, see All Toolkits.
26 Discussions
icx: warning: '-x CORE-AVX512' after last input file has no effect [-Wunused-command-line-argument]
RAJ16
I am facing the below error while compiling the flexran22.07.
I have followed all steps like compiling SDK first +DPDK then compiling flexran with below-mentioned command. Please let me the fix. Thanks
./flexran_build.sh -e -r 5gnr -i avx512 -x icx
ICX & GCC version are mentioned below and centOS is 7.9.
[root@byg4lq3 flexran_src]# icx -v
Intel(R) oneAPI DPC++/C++ Compiler 2022.2.1 (2022.2.1.20221020)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2022.2.1/linux/bin-llvm
Configuration file: /opt/intel/oneapi/compiler/2022.2.1/linux/bin/icx.cfg
Found candidate GCC installation: /opt/rh/devtoolset-8/root/usr/lib/gcc/x86_64-redhat-linux/8
Selected GCC installation: /opt/rh/devtoolset-8/root/usr/lib/gcc/x86_64-redhat-linux/8
Candidate multilib: .;@m64
Candidate multilib: 32;@m32
Selected multilib: .;@m64
[root@byg4lq3 flexran_src]# gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/opt/rh/devtoolset-8/root/usr/libexec/gcc/x86_64-redhat-linux/8/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../configure --enable-bootstrap --enable-languages=c,c++,fortran,lto --prefix=/opt/rh/devtoolset-8/root/usr --mandir=/opt/rh/devtoolset-8/root/usr/share/man --infodir=/opt/rh/devtoolset-8/root/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-shared --enable-threads=posix --enable-checking=release --enable-multilib --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-gcc-major-version-only --with-linker-hash-style=gnu --with-default-libstdcxx-abi=gcc4-compatible --enable-plugin --enable-initfini-array --with-isl=/builddir/build/BUILD/gcc-8.3.1-20190311/obj-x86_64-redhat-linux/isl-install --disable-libmpx --enable-gnu-indirect-function --with-tune=generic --with-arch_32=x86-64 --build=x86_64-redhat-linux
Thread model: posix
gcc version 8.3.1 20190311 (Red Hat 8.3.1-3) (GCC)
please check the console print below:
[CC] wls_lib_dpdk.o
[CC] syslib.o
[AR] libwls.so
libwls.so
Building wls_test
[BUILD] elf : wls_test
[DEP] wls_test.dep
[CC] pool.o
[CC] testapp.o
testapp.c:639:9: warning: variable 'nBlocksSlave' set but not used [-Wunused-but-set-variable]
U32 nBlocksSlave = 0;
1 warning generated.
[LD] wls_test
wls_test
Building MLOG /workspace/22.07/flexran_src/libs/mlog. Running build.sh xclean && build.sh
icx -c -g -Wall -DUSE_LINUX -DMLOG_ENABLED -O3 -fPIC -Werror -UMLOG_SYS_CLOCK_TICK -D_POSIX_PRIORITY_SCHEDULING -D_GNU_SOURCE -pthread -mcmodel=large -Isource -xCORE-AVX512 -O -o tmp/mlog_example_main.o -c source/mlog_example_main.c
icx -c -g -Wall -DUSE_LINUX -DMLOG_ENABLED -O3 -fPIC -Werror -UMLOG_SYS_CLOCK_TICK -D_POSIX_PRIORITY_SCHEDULING -D_GNU_SOURCE -pthread -mcmodel=large -Isource -xCORE-AVX512 -O -o tmp/mlog_lnx.o -c source/mlog_lnx.c
ar rcs bin/libmlog.a tmp/mlog_lnx.o
icx -o bin/mlog_example tmp/mlog_example_main.o -Lbin -lmlog
Building CPA /workspace/22.07/flexran_src/libs/cpa/rec
Compiling for icx...
NR Project clean...
Cleaning Device Driver...
Cleaning Shared library...
Cleaning icx...
NR Project Build...
Makefile
Building Device Driver...
Copying Driver to BIN Path
Building Shared library...
icx: warning: Note that use of '-g' without any optimization-level option will turn off most compiler optimizations similar to use of '-O0' [-Wdebug-disables-optimization]
Copying library to BIN Path
Creating Device Node
Inserting NR Driver Module
Building XRAN lib /workspace/22.07/flexran_src/libs/xran
Number of commandline arguments: 1
xclean
MLOG folder is not set. Disable MLOG (MLOG_DIR=)
DIR_WIRELESS_FW folder is set. Enable FWK (DIR_WIRELESS_FW=/workspace/22.07/flexran_src/framework)
Building xRAN Library for O-RU
LIBXRANSO = 0
MLOG = 0
FWK = 1
ORU = 1
CODE_COVERAGE= 0
[CLEAN] : libxran-oru
[XCLEAN] : libxran-oru
Building xRAN O-RU Test Application
[CLEAN] : sample-app-ru
[XCLEAN] : sample-app-ru
Building xRAN Library for O-DU
LIBXRANSO = 0
MLOG = 0
FWK = 1
ORU = 0
POLL_EBBU_OFFLOAD = 0
CODE_COVERAGE = 0
[CLEAN] : libxran
[XCLEAN] : libxran
Building xRAN O-DU Test Application
GTEST_ROOT is not set. Unit tests are not compiled
"echo "GTEST_ROOT is not set. Unit tests are not compiled"" command exited with code 0.
Number of commandline arguments: 0
LIBXRANSO = 0
MLOG = 0
FWK = 1
ORU = 1
CODE_COVERAGE= 0
Building build-oru/libxran-oru.a
RTE_TARGET = x86_64-native-linux-icc
[BUILD] lib : libxran-oru
[DEP] libxran-oru.dep
icpx: warning: '-x core-avx512' after last input file has no effect [-Wunused-command-line-argument]
icpx: warning: overriding '-march=icelake-server' option with '-x core-avx512' [-Woverriding-t-option]
[CC] /workspace/22.07/flexran_src/xran/lib/ethernet/ethdi.o
[CC] /workspace/22.07/flexran_src/xran/lib/ethernet/ethernet.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_up_api.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_sync_api.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_timer.o
/workspace/22.07/flexran_src/xran/lib/src/xran_timer.c:239:26: warning: variable 't1' set but not used [-Wunused-but-set-variable]
uint64_t t1;
/workspace/22.07/flexran_src/xran/lib/src/xran_timer.c:270:34: warning: variable 't1' set but not used [-Wunused-but-set-variable]
uint64_t t1;
2 warnings generated.
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_cp_api.o
/workspace/22.07/flexran_src/xran/lib/src/xran_cp_api.c:2416:13: warning: variable 'i' set but not used [-Wunused-but-set-variable]
int32_t i;
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_transport.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_common.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_ul_tables.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_frame_struct.o
/workspace/22.07/flexran_src/xran/lib/src/xran_frame_struct.c:345:82: warning: variable 'numSpSlots' set but not used [-Wunused-but-set-variable]
uint32_t numDlSlots = 0, numUlSlots = 0, numSpDlSlots = 0, numSpUlSlots = 0, numSpSlots = 0;
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_dev.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_rx_proc.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_tx_proc.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_cp_proc.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_cb_proc.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_mem_mgr.o
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_main.o
/workspace/22.07/flexran_src/xran/lib/src/xran_main.c:822:14: warning: variable 'reg_sfn' set but not used [-Wunused-but-set-variable]
uint32_t reg_sfn = 0;
/workspace/22.07/flexran_src/xran/lib/src/xran_main.c:2036:10: warning: unused variable 't1' [-Wunused-variable]
long t1 = MLogTick();
[CC] /workspace/22.07/flexran_src/xran/lib/src/xran_delay_measurement.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_compression.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_ref.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane8.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane16.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane32.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane64.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_uplane_9b16rb.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_uplane.o
[CPP] /workspace/22.07/flexran_src/xran/lib/src/xran_mod_compression.o
[CPP-SNC] /workspace/22.07/flexran_src/xran/lib/src/xran_compression_snc.o
[CPP-SNC] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane8_snc.o
[CPP-SNC] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane16_snc.o
[CPP-SNC] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane32_snc.o
[CPP-SNC] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_cplane64_snc.o
[CPP-SNC] /workspace/22.07/flexran_src/xran/lib/src/xran_bfp_uplane_snc.o
[AR] libxran-oru.a
Not building xRAN Test Application...
LIBXRANSO = 0
MLOG = 0
FWK = 1
ORU = 0
CODE_COVERAGE = 0
Building build/libxran.a
[DEP] libxran.dep
uint64_t t1;
uint64_t t1;
int32_t i;
[AR] libxran.a
build/libxran.a
Building 5GNR L1APP /workspace/22.07/flexran_src/build/nr5g/gnb/l1app. Running build_phy.sh xclean && build.sh
Number of commandline: 1
RELEASEBUILD=1
NEW_FRAMEWORK: 0
BUILD_AS_LIB: 0
POLL_EBBU_OFFLOAD: 0
COMMAND_LINE=xclean
Building l1app:
RTE_SDK = /workspace/22.07/DPDK_2207
DIR_WIRELESS_SDK = /workspace/22.07/flexran_src/sdk/build-avx512-icx
DIR_WIRELESS_FW = /workspace/22.07/flexran_src/framework
XRAN_DIR = /workspace/22.07/flexran_src/xran
CPA_DRV_DIR = ../libs/cpa/bin
CPA_DRV_SRC_DIR = ../libs/cpa
CPA_LIB = cpadrv
NEW_FRAMEWORK = 0
BUILD = Release
WIRELESS_SDK_TOOLCHAIN = icx
TARGET_PROCESSOR = -xCORE-AVX512
TARGET_FLAGS = -DPHY_AVX512 -qopt-zmm-usage=high
[CLEAN] : auxlib
[XCLEAN] : auxlib
[CLEAN] : l1app
[XCLEAN] : l1app
RELEASEBUILD=1
NEW_FRAMEWORK: 1
BUILD_AS_LIB: 0
COMMAND_LINE=
Building l1app:
CPA_LIB = cpadrv
NEW_FRAMEWORK = 1
BUILD = Release
[BUILD] lib : auxlib
[DEP] auxlib.dep
[CC] auxlib/bbdev/aux_bbdev.o
[CC] auxlib/bbdev/aux_bbdev_nr5g.o
[CC] auxlib/bbdev/aux_bbdev_stats.o
[CC] auxlib/cline/aux_cline.o
[CC] auxlib/cmgr/aux_cmgr.o
[CC] auxlib/cmgr/aux_cmd.o
[CC] auxlib/ethernet/ethernet.o
[CC] auxlib/ethernet/ethdi.o
[CC] auxlib/ethernet/flow.o
[CC] auxlib/phycfg/phycfg.o
[CC] auxlib/phydi/phydi.o
[CC] auxlib/phydi/dataint.o
[CC] auxlib/power/aux_power.o
auxlib/power/aux_power.c:288:9: warning: variable 'n_core_powered' set but not used [-Wunused-but-set-variable]
int n_core_powered = 0;
auxlib/power/aux_power.c:285:9: warning: variable 'n_core_max' set but not used [-Wunused-but-set-variable]
int n_core_max = 0;
[CC] auxlib/print/aux_print.o
[CC] auxlib/sys/aux_sys.o
auxlib/sys/aux_sys.c:507:14: warning: variable 'cnt' set but not used [-Wunused-but-set-variable]
uint32_t cnt = 0;
[CC] auxlib/timer/aux_timer.o
[CC] auxlib/wls/aux_wls.o
[CC] auxlib/wls/aux_wls_mac2phy_api_recv.o
[CC] auxlib/wls/aux_wls_phy2mac_api_proc.o
[CC] auxlib/ebbupool/aux_ebbu_pool.o
[CC] auxlib/ebbupool/aux_ebbu_pool_core.o
[CC] auxlib/ebbupool/aux_ebbu_pool_event.o
[CC] auxlib/ebbupool/aux_ebbu_pool_stats.o
[CC] auxlib/ebbupool/aux_ebbu_pool_timing_tasks.o
[CC] auxlib/ebbupool/aux_ebbu_pool_utils.o
[AR] libauxlib_r.a
[BUILD] elf : l1app
[DEP] l1app.dep
icpx: warning: '-x CORE-AVX512' after last input file has no effect [-Wunused-command-line-argument]
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_proc_dl_config.o
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_proc_ul_config.o
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_error_check.o
nr5g/api/mac2phy/gnb_mac2phy_api_error_check.c:777:40: warning: variable 'numBch' set but not used [-Wunused-but-set-variable]
uint32_t numPdsch = 0, numBch = 0, numCSI = 0;
nr5g/api/mac2phy/gnb_mac2phy_api_error_check.c:777:52: warning: variable 'numCSI' set but not used [-Wunused-but-set-variable]
nr5g/api/mac2phy/gnb_mac2phy_api_error_check.c:708:28: warning: variable 'localFirstSfn' set but not used [-Wunused-but-set-variable]
uint32_t txSfn, rxSfn, localFirstSfn = 0;
3 warnings generated.
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_proc.o
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_proc_phy_init.o
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_proc_phy_start.o
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_proc_phy_stop.o
[CC] nr5g/api/mac2phy/gnb_mac2phy_api_recv.o
[CC] nr5g/api/phy2mac/gnb_phy2mac_api_proc.o
[CC] nr5g/api/phy2mac/gnb_phy2mac_api_rxsdu_proc.o
[CC] common/mem_mgr/mem_mgr.o
common/mem_mgr/mem_mgr.c:296:14: warning: variable 'leak' set but not used [-Wunused-but-set-variable]
uint32_t leak = 0, numAlloc;
[CC] common/globals/common_globals.o
[CC] common/context/phy_context.o
common/context/phy_context.c:98:14: warning: variable 'numDlSlots' set but not used [-Wunused-but-set-variable]
common/context/phy_context.c:98:30: warning: variable 'numUlSlots' set but not used [-Wunused-but-set-variable]
common/context/phy_context.c:98:46: warning: variable 'numSpDlSlots' set but not used [-Wunused-but-set-variable]
common/context/phy_context.c:98:64: warning: variable 'numSpUlSlots' set but not used [-Wunused-but-set-variable]
common/context/phy_context.c:98:82: warning: variable 'numSpSlots' set but not used [-Wunused-but-set-variable]
5 warnings generated.
[CC] common/info_trace_tool/info_trace_tool.o
common/info_trace_tool/info_trace_tool.c:242:14: warning: variable 'nNumDbgMsg' set but not used [-Wunused-but-set-variable]
uint32_t nNumDbgMsg = 0;
[CC] common/info_trace_tool/info_trace_print.o
[CC] nr5g/gnb_common/gnb_phy_globals_interface.o
[CC] nr5g/gnb_common/gnb_phy_conn_users_info.o
[CC] nr5g/gnb_common/gnb_phy_stats.o
nr5g/gnb_common/gnb_phy_stats.c:2462:14: warning: variable 'numDone' set but not used [-Wunused-but-set-variable]
uint32_t numDone, numChannels, numDlChannels;
[CC] nr5g/gnb_ul/gnb_ul_phy_interface.o
[CC] nr5g/gnb_ul/gnb_ul_phy_pusch.o
[CC] nr5g/gnb_ul/gnb_ul_phy_pusch_uci_decode.o
[CC] nr5g/gnb_ul/gnb_ul_phy_prach.o
[CC] nr5g/gnb_ul/gnb_ul_phy_pucch.o
nr5g/gnb_ul/gnb_ul_phy_pucch.c:1559:13: warning: variable 'numChan' set but not used [-Wunused-but-set-variable]
int32_t numChan = 0;
nr5g/gnb_ul/gnb_ul_phy_pucch.c:1798:13: warning: variable 'numChan' set but not used [-Wunused-but-set-variable]
[CC] nr5g/gnb_ul/gnb_ul_phy_srs.o
[CC] nr5g/gnb_ul/gnb_ul_tables.o
[CC] nr5g/gnb_dl/gnb_dl_phy_interface.o
[CC] nr5g/gnb_dl/gnb_dl_phy_beam_weights.o
[CC] nr5g/gnb_dl/gnb_dl_phy_pbch.o
[CC] nr5g/gnb_dl/gnb_dl_phy_csirs.o
[CC] nr5g/gnb_dl/gnb_dl_phy_pdsch.o
nr5g/gnb_dl/gnb_dl_phy_pdsch.c:104:13: warning: variable 'numChan' set but not used [-Wunused-but-set-variable]
nr5g/gnb_dl/gnb_dl_phy_pdsch.c:869:31: warning: variable 'numChan' set but not used [-Wunused-but-set-variable]
int16_t nDmrsSymbNum = 0, numChan = 0;
[CC] nr5g/gnb_dl/gnb_dl_phy_pdcch.o
[CC] nr5g/gnb_main/gnb_main_interface.o
[CC] nr5g/gnb_main/gnb_main_io_fec_bbdev.o
[CC] nr5g/gnb_main/gnb_main_io_fft_bbdev.o
[CC] nr5g/gnb_main/gnb_main_urllc_thread.o
[CC] nr5g/gnb_main/gnb_main_io_fh_terasic.o
[CC] nr5g/gnb_main/gnb_main_io_fh_xran.o
[CC] nr5g/gnb_main/gnb_main.o
[CC] nr5g/gnb_main/gnb_main_ebbu_pool_tasks.o
[CC] nr5g/gnb_dl/gnb_dl_phy_ebbu_pool_tasks.o
[CC] nr5g/gnb_ul/gnb_ul_phy_ebbu_pool_tasks.o
[CC] nr5g/common/nr5g_data_proc.o
[CC] nr5g/common/nr5g_dmrs_generation.o
[CC] nr5g/common/nr5g_ran_table.o
[CC] nr5g/common/nr5g_utils.o
[CC] nr5g/common/nr5g_sw_fpga.cpp
[CPP] nr5g/phy_modules/pn_compensation/phy_rx_phase_noise_compen.o
[CPP] nr5g/phy_modules/re_demap/phy_rx_re_demap.o
[CPP] nr5g/phy_modules/remap/phy_tx_remap.o
[CPP] nr5g/phy_modules/low_papr_seq_gen/phy_seq_generation.o
[CPP] nr5g/phy_modules/ifft2048/phy_ifft2048.o
[AR] ../bin/nr5g/gnb/l1/l1app
[LD] ../bin/nr5g/gnb/l1/l1app
[APP] ../bin/nr5g/gnb/l1/l1app
Building 5GNR TESTMAC /workspace/22.07/flexran_src/build/nr5g/gnb/testmac. Running build.sh xclean && build.sh
Number of commandline: 0
Building 5gnr testmac:
regenerating dep files
icx: error: Note that use of '-g' without any optimization-level option will turn off most compiler optimizations similar to use of '-O0' [-Werror,-Wdebug-disables-optimization]
icx: error: '-x CORE-AVX512' after last input file has no effect [-Werror,-Wunused-command-line-argument]
make: *** [../build/nr5g/gnb/testmac/makefile:239: __dep__common/mem_mgr/mem_mgr.c] Error 1
DeividA_Intel
Hello RAJ16,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your computer.
1. Are developing software or hardware?
2. Is this a business or personal project?
3. Are you using a laptop or desktop computer?
4. Are you using Linux operating system?
5. can you provide more details about your issue?
Deivid A.
RAJ16
Please find the response below.
Ans:- software
Ans-Business
Ans:- As you can see in the above logs where I have mentioned CentOS7.9
Ans--yes
--while compiling above issues are occurring which was mentioned in the above logs(initial email).
Please look into it and provide solutions.
DeividA_Intel
Hello RAJ16,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
RAJ16
yes, I have responded. Please check once. Thanks
DeividA_Intel
Hello RAJ16,
Thanks for the information provided. Before I proceed to investigate this issue I would like to confirm the following:
1. What is the brand and model name of your wireless adapter?
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Based on your response, you have CentOS 7.9. Have you tried with Ubuntu operating system?
Deivid A.
RAJ16
hi David,
this is intel product WP server 6248R. Could you please provide some pointer?
Please ask all queries in one go. would be more helpful and curtail the time gap.
Raj
DeividA_Intel
Hello RAJ16,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello RAJ16,
Based on your issue and the investigation performed, the Intel SDK forums are the correct place to check this problem.
I will move this thread to the proper forum so you can get assistance related to your issue.
Thanks for your comprehension
Deivid A.
RAJ16
Hi David,
The issue is with testmac not with SDK.
Please check the log where the testmac application is not getting built with ICX.
hnhan
While waiting for the official help, it looks like adding a couple more "no" flags to testmac makefile can get it built.
diff --git a/makefile b/makefile
index feaa27d..8bde15b 100644
--- a/makefile
+++ b/makefile
@@ -137,7 +137,7 @@ DEFS := $(DEFS) XRAN_TIMING_ADAPT
endif
DEFS := $(addprefix -D,$(DEFS))
-CFLAGS := -g -Wall -Wno-deprecated-declarations -Wimplicit-function-declaration -fasm-blocks $(DEFS) $(INC) -I $(RTE_INC) $(TARGET_PROCESSOR) #-DDPDKIO_DEBUG
+CFLAGS := -g -Wall -Wno-unused-command-line-argument -Wno-debug-disables-optimization -Wno-unused-but-set-variable -Wno-deprecated-declarations -Wimplicit-function-declaration -fasm-blocks $(DEFS) $(INC) -I $(RTE_INC) $(TARGET_PROCESSOR) #-DDPDKIO_DEBUG
ifeq ($(PRINTDBG),)
CFLAGS := $(CFLAGS) -Werror
RAJ16
hi,
CFLAGS are already present.
CFLAGS := -g -Wall -Wno-deprecated-declarations -Wimplicit-function-declaration -fasm-blocks -mcmodel=large $(DEFS) $(INC) -I $(RTE_INC) $(TARGET_PROCESSOR) #-DDPDKIO_DEBUG
I do not make any changes in the makefile.
GouthamD
Hi, I am getting exact similar error during building TestMac with FlexRAN 22.11
Building 5GNR TESTMAC /home/flexrannew/build/nr5g/gnb/testmac. Running build.sh xclean && build.sh
RTE_SDK = /opt/dpdk-22.11/dpdk-21.11/
DIR_WIRELESS_SDK = /home/flexrannew/sdk/build-avx512-icx
DIR_WIRELESS_FW = /home/flexrannew/framework
XRAN_DIR = /home/flexrannew/xran
make: *** [../build/nr5g/gnb/testmac/makefile:244: __dep__common/mem_mgr/mem_mgr.c] Error 1
Tianhang
Hi, You can try replacing -xCORE-AVX512 in the makefile with -march=skylake-avx512
Tianhang
