7303 Discussions
A exception is thorwn when using Direct Sparse Solver (DSS) Interface Routines
wzc
Hello everyone,
I am running the example code of  "dss_unsym.c"  from the Intel® oneAPI Math Kernel Library installation directory. However,  there is a exception thorwn (0xC06D007F: Procedure not found (Parameter: 0x0000005F23CFC890) when runing the routine "dss_factor_real".
How could I solve this problem?
Gennady_F_Intel
if you links again mkl_intel_ilp64.lib then you need to use /DMKL_ILP64  compiler option.
or if you links against mkl_intel_lp64.lib - then you don't need to add some additional compilers' mode.
Gennady_F_Intel
How did you link and run this example? check how properly links again mkl follow this link. Please set all needed environment variables to the system paths in advance of running this case.
--Gennady
wzc
Thank you very much for your reply.
I think that I have  properly set all needed environment variables (The additional dependencies include: mkl_intel_ilp64.lib, mkl_intel_thread.lib, mkl_core.lib and libiomp5md.lib), because I can properly run other examples, such as those related to LAPACK Linear Equation Computational Routines.
Gennady_F_Intel
wzc
wzc
Dear Gennady,
Thank you for your response. I've utilized the /DMKL_ILP64 -I"%MKLROOT%\include" compiler option in Visual Studio 2022, but
unfortunately, the issue persists.
How can I resolve this problem?
Thanks!
Gennady_F_Intel
I made a trivial experiments to show you how you could try to build and run this case with the following conditions:
#Compiler used
icx --version
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2024.0.0 Build 20231017
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
Intel(R) oneAPI DPC++/C++ Compiler 2024.0.0 (2024.0.0.20231017)
Target: x86_64-pc-windows-msvc
Thread model: posix
InstalledDir: C:\Apps\Intel\oneAPI\compiler\2024.0\bin\compiler
Configuration file: C:\Apps\Intel\oneAPI\compiler\2024.0\bin\compiler\..\icx.cfg
# Compilation
icx /Qmkl dss_unsym.c
# running the code
dss_unsym.exe
Solving NON_TRANSPOSE system...
Print solution array: -0 1 2 3 4
Solving TRANSPOSE system...
Solving CONJUGATE_TRANSPOSE system...
Example successfully PASSED!
Gennady_F_Intel
#Compiler used
icx --version
Thread model: posix
# Compilation
# running the code
dss_unsym.exe
wzc
Dear Gennady,
I have downloaded the latest version of Intel oneMKL. Everything is now working correctly.
Thank you for your assistance!
wzc
