Access violation with MKL_DSS
Luis_A_
Hi there,
I found a strange problem when using MKL DSS, something related with "Access violation writing location", either with DSS_FACTOR_REAL or DSS_SOLVE_REAL. Problem seems to be computer dependent.
I prepared a small program with which the problem can be found.
In brief, we have a system of equations with neq=8, which I am trying to solve.
In some cases, like neq=8, when I try to solve the same system of equations twice, the problem appears.
Running:
Intel Visual Fortran Composer XE 2013 14.0.1.139 build 20131008
Windows 7/ Visual studio 2010
Already tried with Windows 8 / VS 2013 / Fortran 15.0.0.108 build 20147026 and the problem is the same.
Luis Alves
Luis_A_
Here is the Fortran code...
mecej4
I am able to test your program with IFort 11.1.070 (MKL 10.2.7), 14.0.4.237 and 15.0.0.108.
Only the oldest of these aborts inside MKL during the first call to DSS_SOLVE_REAL(), with an unhandled exception. The later compilers (with later versions of MKL) build EXEs that run to completion. Is it feasible for you to update your MKL installation?
Luis_A_
I have also version 15.0.0.108, and in may case the problem is the same.
I did not try in release, but in debug I found the same error.
Any solution?
mecej4
Perhaps you have some VS settings that are culpable. It is also possible that there is a hard-to-reproduce bug that surfaces in your runs but not mine.
Here is the transcript of my "debug" compilation and run.
S:\lang\MKL>ifort /Qmkl /Od /traceback /extend_source MKL_problem.for
Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 15.0.0.108 Build 20140726
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 12.00.30723.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:MKL_problem.exe
-subsystem:console
-incremental:no
"-libpath:C:\Program Files (x86)\Intel\Composer XE 2015\mkl\lib\ia32"
MKL_problem.obj
S:\lang\MKL>mkl_problem
S:\lang\MKL>
mecej4
Luis, I have created a simpler reproducer and posted it, see https://software.intel.com/en-us/forums/topic/535447 . The difficulty with this is that the bug does not always occur. When we compile with different compiler options, then run it and experience a crash, we tend to see the options as the probable cause of the crash. However, what I found is that a single EXE, when run multiple times, will run fine and produce correct results most of the time, but will crash now and then.
I think that we have to rely on the Intel people to help with this problem, because it occurs deep inside the MKL library.
