Any long integer packages ?
WSinc
I need to work with REALLY LARGE integers.
What would be ideal is something that allows any length of integer.
The basic operations on those, of course. + - / and *
Has anyone developed those ?
Gennady_F_Intel
MKL suggests 32/64 bit integer only. You may try to take the GMP library for arbitrary precision arithmetic.
WSinc
arbitrary precision is NOT THE SAME as long integer.
mecej4
Bill, you would have better luck with your question in a more appropriate forum, such as the Intel Fortran forums, or in Usenet comp.lang.fortran.
Secondly, you would need to give a more detailed description of what your needs are, since phrases such as "really large" have very little meaning.
The following page contains a number of links that you may examine to see if the available software there would work for you: http://crd-legacy.lbl.gov/~dhbailey/mpdist/ (considering integers as a subset of reals).
See also https://www.fortran.com/big_integer_module.f95 m for an integers-only solution. You will need to know the maximum integer beforehand with this module.
WSinc
I thought LONG INTEGER would be self-explanatory.
I was referring to integers longer than the default length of integer(8)
Now one could get 15 byte integers by declaring variables as real(16).
but that is a sloppy and messy way of going about it.
These are used in cryptography and other branches of mathematics BTW.
