7303 Discussions
Automated parallelizing not working with large matrixes
suarez__eric
I have a code in fortran that calculates eigenvectors and eigenfunctions of matrix and process the results. I use the ifort with the -mkl compilation, the code runs in parallel for an square matrix (N,N) when N is less than 100 (more or less) but when I try larger matrixes N>300 it only runs as one thread.
Any help?
Eric
Please clarify - are you using MKL routines for the eigenvectors and eigenfunctions? Which routines?
suarez__eric
yes, I am calling  zheev to calculate the eigenvalues and eigenvectors then I do some other calculations with the results.
Ok. I am going to move this to the MKL forum, then, where MKL experts can help you.
Gennady_F_Intel
Eric, Could you give us the example to check the problem on our side?
