Basic Code of Using MKL FFT on MIC
Cristian_Vasile_A_
In our local cluster we have a bunch of MIC's, which are (almost) never esed. I would like to give it the try, but I have no experience iwth the MKL library or MIC. My programs are very simple and they are based on FFT:
I have an iterative process in which the smae update procedure is applied to the previous data:
// initialize data rho[lx]
for(t=0;t<tmax;t++)
// first step in real space is local
for(i=0;i<lx;i++)
nt(i)=rho*rho*rho;
//forward FFT rho->rhok
//forward FFT nt-> ntk
//update in k space
for(i=0;i<lx/2+1;i++)
newrhok(i)=filter1(i)*rhok(i)+filter2(i)*ntk(i); // complex multiplication
//inverse FFT newrhok->newrho
So my problem is how to ues MKL FFT's on MIC's and how minimize the transfers between cpu and MIC.
I hope this is the right forum and many thanks in advance
Cristian
Gennady_F_Intel
Cristian,
The best way to to learn how to use MKL for Xeon Phi - to look at the examples which were prepared special for such sort of questions.
in particular for FFT - you can find such example into "<mkl_root>\examples\mic_offload\dftc\"
--Gennady
Cristian_Vasile_A_
Gennady Fedorov (Intel) wrote:
Cristian,
--Gennady
Thank you for your reply. I will check the examples on our cluster.
