CPU Deprecation Warning
Daniel_H
Since MKL 2024.0 I got this nasty warning when using applications compiled and linked with ICX 2024 on Linux:
Intel MKL WARNING: Support of Intel(R) Advanced Vector Extensions (Intel(R) AVX) enabled only processors has been deprecated. Intel oneAPI Math Kernel Library will use Intel(R) Streaming SIMD Extensions 4.2 (Intel(R) SSE4.2) instructions instead.
I'm a bit stumbled by this error/warning since the requirements are:
CPU Processor Requirements
Intel® Core™ Processor Family
and I've got a  Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, which looks like a Core Processor to me.
  1. So why this message ?
  2. Is there any way to remove this warning which clutters some further output capturing processes ?
Thanks a lot for any help,
Daniel_H
After digging a lot, I found a workaround:
export MKL_ENABLE_INSTRUCTIONS=SSE4_2
This forcedly set the instruction set to SSS 4.2 and silences the warning and let the piped instructions proceed. Fair enough...
Nevertheless I would have rather have preferred that the warning went to the stderr and not the stdout... after all that's what stderr is meant for.
AryanK_Intel
As the warning is related to the dependency on the instruction set being used by the processor and not a code error which is related to MKL, it was being printed on stdout. Kindly let us know if you need any other assistance.
Thanks & Regards,
Aryan.
Daniel_H
OK, thanks for the answer.
I'll live with that until I got the money to upgrade to a new CPU...
AryanK_Intel
In case you run into any other issues please feel free to create a new thread.
Thanks & Regards,
Aryan
