Compiling with g++
Jack_K_
How can I compile my program with mkl and g++?
I already tried the mkl line advisor, but I got the "pthread_mutex_trylock" message.
How`s it going ?
Ying_H_Intel
Hi Jack,
Are you working on Ubuntu system?
It looks similiar problem as  http://software.intel.com/en-us/forums/topic/501970#comment-1779725 and the one in http://software.intel.com/en-us/articles/symbol-lookup-error-when-linking-intel-mkl-with-gcc-on-ubuntu.  Some ubuntu and GCC have the issue, some have not.
You may try to add the compiler option : -Wl,--no-as-needed.   for example
g++ -Wall -o test.exe test.cpp -Wl,--no-as-needed -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -ldl -lpthread -lm
Ying
VipinKumar_E_Intel
What is your linkline?
For intel64, lp64 interface, it is something like this.
 -Wl,--start-group $(MKLROOT)/lib/intel64/libmkl_intel_lp64.a $(MKLROOT)/lib/intel64/libmkl_core.a $(MKLROOT)/lib/intel64/libmkl_gnu_thread.a -Wl,--end-group -ldl -lpthread -lm
Have you threaded your program with pthreads?
--Vipin
Jack_K_
No, I don't thread with pthreads.
TimP
The point is, somewhere in your build you are calling a pthread function, e.g. by using OpenMP in your own code or by linking an mkl_thread library.  You will need either to remove the pthread function usage or link properly to support it.
Ying_H_Intel
Hi Jack,
Ying
Jack_K_
It works. Thank you everybody.
