Const correctness
asd__asdqwe
Is there a reason the parameters of mkl_sparse_?_create_[b|c]sr are of type C_INT or C_[FLOAT|DOUBLE|FLOAT_COMPLEX|DOUBLE_COMPLEX] instead of const C_INT const or const C_[FLOAT|DOUBLE|FLOAT_COMPLEX|DOUBLE_COMPLEX] const? Do you modify the pointers or the values provided by the user? I currently need to use ugly const_cast because my pointers are of type const T* const. E.g.,
            mkl_sparse_d_create_bsr(&bsr, SPARSE_INDEX_BASE_ONE, SPARSE_LAYOUT_COLUMN_MAJOR, *m, *k, *bs, const_cast<int*>(ia), const_cast<int*>(ia + 1), const_cast<int*>(ja), const_cast<double*>(a));
Any chance this could get fixed?
Gennady_F_Intel
Yes, we definitely should add this. we should add const modifier to many others SpBLAS IE API. We will keep you posted with on the progress.
Gennady_F_Intel
The issue has been fixed into the latest v2020 which was released the last week.
