7157 Discussions
Custom dll builder tool in Intel MKL 9.1 is broken and the fix will be in next update version
VipinKumar_E_Intel
We have found a few bugs in the custom DLL builder tools shipped with Intel MKL 9.1 for Windows* andits updates (versions 9.1.022 and 9.1.025). The fixed version of the tool will be available in next update to Intel MKL which will be released soon.
Vipin
Software & Solutions Group
Intel Corp.
kelnze
Hello Andrey;
I have Intel Math Kernel Library 9.1.027.I want use them(.lib file and .dll file) on the C++ Builder, However, I don't know how to use. You canhave advice for me.
Looking forward your advice!
BestsRegards!
Andrey_G_Intel2
Kelnze, if you look thru "mkl release notes" you see what MKL don`t support compilers from Borland. I think, but workaround exist.
It`s imposible to use MKL statical libraries with borland compilers because borland compilers don`t work with libraries in microsoft format. Main idea - build MKL custom dll and use them in your borland project (via LoadDll or via creating import library).
See our disscussion wit rockballad (http://software.intel.com/en-us/forums//topic/54883).
kelnze
Thank you for your help!
I can use custom dll and link them with borland. However, to use MKL how I must do, I must custom alldll in MKL, right?
Thanks! Andrey!
Andrey_G_Intel2
If you plan to use MKL with borland - here is only one way- via custom dll builder tool. If you plan to use MKL with supported compilers - you should read MKL documentation. In manual you can find answer to your question :-)
yuriisigal
After construction .dll you have operating library .lib. Change a format of library .lib (coff->omf) and work in C ++ Builder.
