7303 Discussions
DGESVD Access Violation for m>n particular values
sragner
This testprogram creates an access violation under VS C++ 6.0 with MKL 8.0.1
The values 350x320 is important while for some combinations of sizes it works correctly
For example: 350x220 is faulty, 350x219 is ok, 500x314 is faulty, 500x313 is ok.
What can be the problem?
char jobu = 'S';
char jobvt = 'S';
int m = 350;
int n = 320;
int minmn= m>n?n:m;
int maxmn= m>n?m:n;
double* a = new double[m*n];
double* u = new double[m*minmn];
double* s = new double[minmn];
double* vt= new double[minmn*n];
int lda = m;
int ldu = m;
int ldvt = minmn;
int info = 0;
for ( int i = 0 ; i < m*n ; i++ ) a=((double)rand())/((double)RAND_MAX);
int lwork = -1;
double* work = new double[1];
dgesvd(&jobu , &jobvt , &m , &n , a , &lda , s , u, &ldu , vt , &ldvt , work , &lwork , &info );
lwork = (int)work[0];
delete work;
work = new double[lwork];
sragner
http://softwareforums.intel.com/en-us/forums//topic/49120
Somebody has similar problems as I see.
if I switch jobu to 'N' it works fine (obviously it doesn't calculate U).
The only solution was to complete the matrix to square form with zeros and than extract the solution from the resulting two NxN and Nx1 matrices. This is bad and waste and hack but works till there is a fix for it.
Laszlo
beaupaisley
It appears that in version 801 both SGESVD and DGESVD (but not ZGESVD) have this problem for ill-conditioned matrices. Does anyone know if this has been fixed in subsequent MKL releases?
Beau Paisley
