Disable "MKL POISSON LIBRARY WARNING:"
Mikhail_Matrosov
I'm using s_Helmholtz_2D routine to solve my Poisson equation. I specify Neumann boundary conditions for all boundaries and receive this warning:
The problem is degenerate up to rounding errors! The approximate solution
that provides the minimal Euclidean norm of the solution will be computed...
Yes, I totally understand that and all works fine. So, is there a way do disable this warning? It's just spamming output of my utility.
Alexander_K_Intel2
Try to set ipar[2]=0.
With best regards,
Alexander Kalinkin
Alexander_K_Intel2
With best regards,
Alexander Kalinkin
Mikhail_Matrosov
It works! Thanks a lot!
And by the way: I wouldn't have asked such a simple question if there was convenient search on the reference, really.
Alexander_K_Intel2
You are welcome! :)
This parameter described in common parameters, chapter 13 "Partial differential equations support" of
Intel Math Kernel Library ReferenceManual.
With best regards,
Alexander Kalinkin
Camilo_P_
The instructions given by Alexander Kalinkin are for C++ or a zero based language. For fortran you need to set ipar(3) =0.
