7296 Discussions
Does MKL_SERIAL environment variable obsolete since MKL10.0?
sspine
I have been using MKL since MKL6.0. I noticed that MKL_SERIAL is not mentioned from MKL10.0. Is it obsolete?
TimP
Quoting - sspine
It's obsolete in the case where you don't want to be able to turn on threading in MKL. Then you should link the sequential (stub) library.
sspine
Quoting - tim18
Does this mean it is still useful when I use parallel MKL?
Obviously, it makes no sense for sequential library.
Todd_R_Intel
When using the sequential library then yes, of course no control is needed. If you're using the threaded libraries you can control threading using either traditional OpenMP controls or the MKL controls introduced in MKL 10.0. Threading control functions and environment variables are described in the "Managing Performance and Memory" chapter of the user guide or in the 'Support Functions" chapter of the reference manual. Documents can be found here online.
Todd
