7303 Discussions
Does mkl_sparse_sp2m support multithreading or not?
miaodi1987
I am a new user of MKL library. I mainly use MKL via PETSc function calls. I found that dense matrix multiplication (cblas_dgemm) is multithreaded. However, when I run sparse matrix multiplication (mkl_sparse_sp2m) I only see that it is running in serial mode. Could I know if mkl_sparse_sp2m supports multithreading?
And how should I know if a function in mkl supports multithreading or not?
Thank you!
Di
ShanmukhS_Intel
You can go through the below reference for more details regarding the threading control. We would like to request you to elaborate on your issue for more details regarding the same.
https://www.intel.com/content/www/us/en/docs/onemkl/developer-reference-c/2023-2/threading-
control.html
Shanmukh.SS
ShanmukhS_Intel
A gentle reminder:
Has the information provided helped? Could you please let us know if you need any other information?
Shanmukh.SS
ShanmukhS_Intel
A gentle reminder:
Shanmukh.SS
