7298 Discussions
Error LNK2019: unresolved external symbol PARDISO references in function ANALYS
Usman1710
Hi, I was using VS2010 before, I never had any problem related to mkl_pardiso.f77. However, recently I am using Intel Fortran compiler VS 2019. While trying to buildup the program, following error 'Error LNK2019: unresolved external symbol PARDISO references in function ANALYS' occurs.
Can someone guide please? Thank you!!!
Gennady_F_Intel
You need to check the list of mkl's libraries is recommended for linking by following the mkl linker adviser suggestions and then explicitly add these libs to the VS2019 solution.
Gennady_F_Intel
Usman1710
Thank you for the kind suggestion!!!
Gennady_F_Intel
The issue is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
