7303 Discussions
Error in PARDISO ( numerical_factorization) error_num= -987
Andreas_Fabri__Geome
I try to solve a sparse system with pardiso, using the evaluation version of the Beta of the MKL
on Windows 7, 64.
As I have to enable out-of-core if necessary I initialize the parameters as follows:
m_piparm[0] = 1; // No solver default
m_piparm[1] = 2;
m_piparm[9] = 0;
m_piparm[17] = -1;
m_piparm[20] = 1;
m_piparm[26] = 1;
m_piparm[59] = 1; // out off core if necessary
Here is the trace of the pardiso run. Any help is appreciated, and if necessary
I could dump the sparse symmetric matrix in a file and make it available.
Andreas Fabri
=== PARDISO is running in Out-Of-Core mode, because iparam(60)=1 and there is no
t enough RAM for In-Core ===
================ PARDISO: solving a symm. posit. def. system ================
Summary PARDISO: ( reorder to reorder )
Times:
Time fulladj: 1.618750 s
Time reorder: 48.901887 s
Time symbfct: 6.202610 s
Time malloc : 1.084790 s
Time total : 85.589953 s total - sum: 27.781916 s
Statistics:
< Parallel Direct Factorization with #processors: > 1
< Numerical Factorization with Level-3 BLAS performance >
< Linear system Ax = b>
#equations: 2797565
#non-zeros in A: 23286826
non-zeros in A (): 0.000298
#right-hand sides: 1
< Factors L and U >
#columns for each panel: 128
#independent subgraphs: 0
< Preprocessing with state of the art partitioning metis>
#supernodes: 1300322
size of largest supernode: 3421
number of nonzeros in L 604905508
number of nonzeros in U 1
number of nonzeros in L+U 604905509
Percentage of computed non-zeros for LL^T factorization
0 %
1 %
44 %
Fseek failed
*** Error in PARDISO ( numerical_factorization) error_num= -987
PARDISO Internationalization error! Message -987 is unknown
Summary PARDISO: ( factorize to factorize )
Times:
Time A to LU: 0.000000 s
Factorization: Time for writing to files : 0.000000
Factorization: Time for reading from files : 0.000000
Time numfct : 0.000000 s
Time malloc : 0.053992 s
Time total : 105.836084 s total - sum: 105.782091 s
Statistics:
#equations: 2797565
< Factors L and U >
gflop for the numerical factorization: 886.436031
The error code is : -4
mecej4
This is just a guess -- I have no experience with huge matrices--:
An out-of-core solver needs to write and read large temporary files, so the 'fseek error' suggests that you look at the possibility that the program ran out of disk space while processing the temporary files.
Alexander_K_Intel2
This problem could occur when during LL^T decomposition zero or negative diagonalelement appeared. Try to change mtype =2 on mtype = -2, probably it could resolve the problem.
With best regards,
Alexander Kalinkin
Switching to mtype=-2 did not help. Here is the output.
As you are from Intel. the error_num -987 should help
you to help me, shouldn't it?
best regards,
andreas
The file .\pardiso_ooc.cfg was not opened
================ PARDISO: solving a symmetric indef. system ================
Times:
Time fulladj: 1.662469 s
Time reorder: 49.211687 s
Time symbfct: 6.262312 s
Time malloc : 1.055497 s
Time total : 86.830331 s total - sum: 28.638366 s
Statistics:
#equations: 2796570
#non-zeros in A: 23279108
< Factors L and U >
#supernodes: 1300079
size of largest supernode: 3576
number of nonzeros in L 588215272
number of nonzeros in L+U 588215273
Alexander_K_Intel2
Hi Andreas
The error=-987 is internal error that couldn't appeared in normal situation. Could you check your matrix by setting iparm(27) = 1 in Fortran (iparm[26] in C) and size of free memory on hard disk (you must have around 8Gb free space on HDD). If everything is correct could you send testcase (example with matrix that chrashed) to investigate problem?
With best regards,
Alexander Kalinkin
Gennady_F_Intel
Andreas, how about free space availble on your system?
nnz is ~ 588215272 will require ~ 5 Gb memory available
--Gennady
I have 83 GB available, so disk space should not be the problem.
I also had alreadyt set iparm[26]. For completeness, here are the other parameters I've set.
Could you verify that they are correct. I find it rather error-prone that when I only want
to change one parameter(as out of core), I must figure out for all the others, what the default is.
m_piparm[1] = 2;
m_piparm[9] = 8; // iparm(10)- pivoting perturbation.
m_piparm[17] = -1;
m_piparm[20] = 1;
m_piparm[26] = 1;
Do you have any standard file format that I should use for storing the system?
andreas
Gennady_F_Intel
Andreas,
What MKL beta version you are evaluate?
Could you check how it will works with clear OOC mode ( iparm[59] == 2) instead of hybrid mode you are using.
--Gennady
I downloaded w_mkl_10.3.0.055.exe
Concerning the temporary file, in which directory does it go?
I ask because I am wondering what happens when the virus scanner
(Norton) tries to check it.
andreas
Gennady_F_Intel
by default -the OOC PARDISO uses the current directory for storing data.
Gennady_F_Intel
Thierry,
the same problem with OOC or hybryd mode?
--Gennady
Thierry_LE_SOMMER__E
I tested the two modes (iparam[59]=1 and iparam[59]=2) without success.
I am using MKL 10.2.5.035 with Visual Studio 2008 on Windows 7 x64
Thierry
Gennady_F_Intel
well and you had the similar error == -987?
Here is the log :
ooc_path got by Env = C:\Dev\OptimTopo\Code\ooc_file
ooc_max_core_size got by Env = 3000
ooc_keep_file got by Env = 1
=== PARDISO is running in Out-Of-Core mode, because iparam(60)=2 ===
0 %
1 %
2 %
40 %
41 %
42 %
Fseek failed
*** Error in PARDISO: zero pivot
================ PARDISO: solving a real struct. sym. system ================
Summary PARDISO: ( reorder to factorize )
Times:
Time fulladj: 0.134167 s
Time reorder: 4.507111 s
Time symbfct: 2.230421 s
Time parlist: 2.000479 s
Time malloc : 10.436600 s
Time total : 294.919680 s total - sum: 275.610902 s
Statistics:
< Parallel Direct Factorization with #processors: > 4
< Numerical Factorization with BLAS3 and O(n) synchronization >
#equations: 408483
#non-zeros in A: 31756329
non-zeros in A (): 0.019032
< Factors L and U >
#columns for each panel: 96
#supernodes: 39349
size of largest supernode: 9840
number of nonzeros in L 626636223
number of nonzeros in U 605550762
number of nonzeros in L+U 1232186985
gflop for the numerical factorization: 5644.826505
ERROR during symbolic and numerical factorization: -4*** Error in PARDISO (read/write OOC data file) error_num= 0
I tried MKL 10.3 Beta and i had the same error.
With iparam[27]=0, I got :
0 %
1 %
2 %
40 %
41 %
42 %
Fseek failed
With iparam[27]=1, I got :
0 %
1 %
2 %
83 %
84 %
85 %
Fseek failed
Fseek failed
Fseek failed
This can perhaps help you...
Gennady_F_Intel
Hello guys,because it is completely unknown to us the problem and our internal tests do not reproduce it,
I can only ask to send us this information.
At least this will allow us to significantly speed up this error investigation.
--Gennady
You can download my matrix (ia, ja and a arrays) here : http://lesommer.free.fr/matrix_ed_lesommer.zip
I know that my matrix has zero elements.
Gennady_F_Intel
Thanks, we will check and let you know if any update.
Sergey_Solovev__Inte
We downloaded matrix and successfully factorized it with MKL10.2.5 (see log below).
May be the problem is in free space on hard disc. Number of LU-factors is 1 232 186 985. To store them on hard disc, MKL OOC PARDISO requires about 12GB free space (1 232 186985 *8Byte).
How much free space is on hard disc? Also, please print out iparam[63]. It is internal parameter, which can help us identify the version of MKL PARDISO.
************************************ ooc_max_core_size got by Env = 3000
0 %
1 %
2 %
3 %
98 %
99 %
100 %
Times:
Time fulladj: 0.115263 s
Time reorder: 3.636191 s
Time symbfct: 3.471022 s
Time parlist: 0.321256 s
Time numfct : 428.636476 s
Time malloc : 0.586887 s
Time total : 440.670663 s total - sum: 3.903568 s
Statistics:
#equations: 408483
< Factors L and U >
#supernodes: 39349
gflop/s for the numerical factorization: 13.169263
The free space on the hard disk is not the problem. I have 100Go free.
I think I found the problem. This comes from the library mkl_intel_thread.lib.
With mkl_intel_thread.lib => OK
With mkl_intel_thread_dll.lib => Error -987
Now it works for me with the versions : 10.2.5, 10.2.6 and 10.3.0 beta
Thierry
Gennady_F_Intel
Thierry,
Could you please clarifyhow did you link application when the erro_num = -987 has been encountered?
then, we will try to reproduce the problem on our side also.
--Gennady
