7302 Discussions
Error in opening the Library module file. [MKL_VSL]
f_oliveira
Hi all.
I'm trying to use the mkl 8.0.2 with ifort 9.031 but I can't. I tried a simple program which just load the mkl_vsl libraries (by coding "USE MKL_VSL" in the program) and it doesn't compile and return the message "Error in opening the Library module file [MKL_VSL]". The program compiles correctly when I copy the file /mkl/8.0.2/include to the same directory of the program and compile it first and it accept some variable declarations (of course I can't invoke the functions). I used the scripts mklvars32 to set environment variables (I've tried the 64) and checked. The command I'm using to compile is very simple:
ifort myprog.f -L/opt/intel/mkl/8.0.2/lib/32 -lmkl_ia64
I also tried to put all libraries but. I'm using Fedora 4
Well, I'm sorry if this is a very simple question but I'm novice to this business.
Many thanks.
Message Edited by [email protected] on 04-27-200605:02 AM
Andrey_G_Intel2
It looks like you are using 64bits libraries at 32bits platform or contrariwise. And you forget specify include path to mkl_vsl.fi for compiler.
In your case correct command lines looks as:
for ia32 platforms: ifort -I/opt/intel/mkl/8.0.2/include myprog.f -L/opt/intel/mkl/8.0.2/lib/32 -lmkl_ia32
for ia64 platforms: ifort -I/opt/intel/mkl/8.0.2/include myprog.f -L/opt/intel/mkl/8.0.2/lib/64 -lmkl_ia64
for em64t platforms: ifort -I/opt/intel/mkl/8.0.2/include myprog.f -L/opt/intel/mkl/8.0.2/lib/em64t -lmkl_em64t
f_oliveira
Thanks for the suggestion. I did it and it still wasn't working. There were also a problem with SELinux (by the way it has a problem with matlab also). I deactivated it and it is working now. Thanks.
F
