Fast Cosine Transform?
mandrew
Does anyone know if there is a fast cosine transform routine within the FFT library?
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Mandrew
Hello Mandrew,
There is a part of MKL that realized fast cosine transform -Trigonometric Transform. In details it describe in chapter 13 "Partial Differential Equations Support" of Intel Math Kernel Library Reference Manual
With best regards,
Alexander
mandrew
I have tried using the trigonometric transform, however, I have had some problems using it. It appears that many of the parameters needed to call these routines are associated with the partial differential equation library. Since I don't want to actually use these parameters I am not sure how to initialize/use them. For instance, when I tried using the cosine transform a time-dependent simulation, it was working for the beginning of the simulation, but then I get the following error messages in the terminal:
MKL TRIG TRANSFORMS ERROR:
Initialization has failed to complete, or the parameter ipar[6]=-10000
was altered by mistake outside the d_commit_trig_transform routine
The previous call to an MKL Trigonometric Transform routine produced an error
code, or the parameter ipar[6]=-10000 was altered by mistake outside
the routine. If you are sure that everything is correct, you may force the
routine to work by setting ipar[6]=0 before the call to this routine
The larger the problem size, the sooner these messages pop up during the simulation. Any idea why this might be happening?
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Mandrew
Hello Mandrew,
It's look like init step of TT has failed to complete or was not execute. Could you show in this topic the value of ipar[6] after init step and before commit step?
With best regards,
Alexander
mandrew
Alexander,
I get ipar[6]=1 both after the init step and before the commit step - hope that helps.
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Alexander,
Mandrew
Mandrew,
It's a really strange and look like there are some problems with fortran/C interpretation. Could you show how you call init of TrigTransform?
With best regards,
Alexander
mandrew
Mandrew,
With best regards,
Alexander
Alexander,
I use the same procedure given in the manual:
CALL D_INIT_TRIG_TRANSFORM(N,MKL_COSINE_TRANSFORM,ipar,dpar,ir)
How should I be initializing ipar, dpar, and ir?
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Alexander,
Mandrew
Mandrew,
D_INIT_TRIG_TRANSFORM must initializing ipar, dpar and ir itself, you need only allocate these arrays. As I understood, your program developed by Fortran, so could you show the value of ipar(7) and how you call D_COMMIT_TRIG_TRANSFORM?
With best regards,
Alexander
mandrew
Mandrew,
With best regards,
Alexander
Alexander,
Yes, I am using fortran 90. I get ipar(7)=0 after INIT step. I then call the routine using:
CALL D_COMMIT_TRIG_TRANSFORM(Vector,handle_dct,ipar,dpar,ir)
CALL D_FORWARD_TRIG_TRANSFORM(Vector,handle_dct,ipar,dpar,ir)
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Alexander,
Mandrew
Mandrew,
The situation is really strange for me. The error, you wrote below could be appeared only if ipar(7) is equal -10000. ipar(7) could be equal -10000 if you call commit or forward/backward with ipar(7) not equal zero, so to get ipar(7) = -10000 you need to call commit with ipar(7) not equal zero twice. The variant, if you sure that you didn't change internal data you can set ipar(7) =0 before commit, but you wrote that it is so. The better solution I see if you could develop test case of this problem and attach it here?
With best regards,
Alexander
mandrew
Mandrew,
With best regards,
Alexander
Alexander,
I will paraphrase my code here since it is rather lengthy. Essentially I am performing a time-dependent simulation that takes many forward/backward cosine transforms at each time step. It looks something like this:
DO iter=1,itermax
DO i=1,N
( Solve for vecnew here )
END DO
DO i=1,N
CALL D_COMMIT_TRIG_TRANSFORM(vecnew(:,i),handle_dct,ipar,dpar,ir)
CALL D_BACKWARD_TRIG_TRANSFORM(vecnew(:,i),handle_dct,ipar,dpar,ir)
END DO
vecold=vecnew
END DO
Is there anything that I might be doing incorrectly with the cosine transform in the above example?
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Alexander,
DO iter=1,itermax
DO i=1,N
END DO
DO i=1,N
END DO
vecold=vecnew
END DO
Mandrew
Hi Mandrew,
I think that problem is that your program try to initializate one handle several times. So try to change your program in next way:
DO i=1,N
END DO
As additional you will have increase in performance :)
With best regards,
Alexander
mandrew
Hi Mandrew,
DO i=1,N
END DO
With best regards,
Alexander
Alexander,
Is it possible to only use one COMMIT step prior to beginning the simulation for many vectors and for forward and backward transforms? In other words can I do the following:
CALL D_COMMIT_TRIG_TRANSFORM(vecnew1(:,1),handle_dct,ipar,dpar,ir)
DO iter=1,itermax
DO i=1,N
( Solve for all vecnew* here )
END DO
DO i=1,N
CALL D_BACKWARD_TRIG_TRANSFORM(vecnew1(:,i),handle_dct,ipar,dpar,ir)
CALL D_BACKWARD_TRIG_TRANSFORM(vecnew2(:,i),handle_dct,ipar,dpar,ir)
CALL D_BACKWARD_TRIG_TRANSFORM(vecnew3(:,i),handle_dct,ipar,dpar,ir)
END DO
DO i=1,N
CALL D_FORWARD_TRIG_TRANSFORM(vecnew1(:,i),handle_dct,ipar,dpar,ir)
CALL D_FORWARD_TRIG_TRANSFORM(vecnew2(:,i),handle_dct,ipar,dpar,ir)
CALL D_FORWARD_TRIG_TRANSFORM(vecnew3(:,i),handle_dct,ipar,dpar,ir)
END DO
END DO
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Alexander,
DO iter=1,itermax
DO i=1,N
END DO
DO i=1,N
END DO
DO i=1,N
END DO
END DO
Mandrew
Mandrew,
Yes, If you want to use Forward/Backward TrigTransform with one tt_type and with one dimension (N) several times the best way to using it - as in your example
With best regards,
Alexander
mandrew
Mandrew,
With best regards,
Alexander
Alexander,
Yes, placing one init step before the time-stepping loop began has fixed issue.
Mandrew
Alexander_K_Intel2
Quoting - mandrew
Alexander,
Mandrew
Hi Mandrew,
You are welcome,
Alexander
