7303 Discussions
How to get/compute achieved GFlops Performance
matthiasd
Hello!
I am currently using the Intel MKL for research activities.
For rough performance estimation I coded some benchmarks. But I am not sure how to compute the actual reached GFlops Performance. Due to the fact that I don't know how much actual floting point operations the blas function really executes.
(on the Intel Website I found benchmark graph with dimension on x-axis and GFlops on the y-axis.)
here is an example from my results
  • Intel Q6600, 2.4 GHz, 2 GB RAM
  • cblas_sgemm (C <- alpha * A * B + beta * C)
  • matrix sizes of 3000x3000 (random values, full filled)
  • computing time: 3.350 seconds
I am also interessted in some hard facts about the Q6600 like
  • peak GFlops Performance
  • cycles for a float/double operation (i guess several float ops per cycle with SSE, Pipelining, ...)
Thanks for your anwsers. I would by really nice to get reliable data at first hand.
TimP
There's little question about the number of floating point operations in matrix multiply, given that MKL is a work-alike for public BLAS, but plenty of useful reading accessible with a few clicks in your browser.
Noting that Core 2 Quad is identical architecturally to predecessor versions of Core 2, except for number of cores, if you are serious about research, you should refer to the processor manuals http://www.intel.com/products/processor/manuals/
The primary ratings for cycles per operation are throughput (msximum retirement period) and latency (serial period).
Linpack Top 500 ratings refer to efficiency (floating point operations completed)/(theoretical peak). Beyond that, such calculations have little practical use. http://www.top500.org/ Are you starting a category of "hard, but nearly useless" facts?
Note that Core 2 Quad is labeled as Kentsfield on the Top 500 site. 5420 of them to achieve a score of 32800 Gflops (double precision).
