7301 Discussions
How to get the information about improve speed in cluster_sparse_solver distributed assembled matrix version
DongHee_B_
Hi. I test to get solution about non-symmetric matrix Ax=B used cluster version direct sparse solver.
I used to MKL 2018 update 3 and the compiler is VS 2017.
I test to my application used cluster_sparse_solver both option centralized and distributed. (iparm[39])
And the solving time of distributed option solver is x3 ~ x5 slower than centralized option solver.
(The size of matrix about quarter million. Used same A and B, Ax = b result is same)
I tried the start and end domain number of distributed option solver is just divided number of process. (4 process, 0 ~ 30000, 30001~60000, ...)
Is there anything I did wrong? If not, what information should be used to divide the domain?
Gennady_F_Intel
Application Note: "Performance of the reordering step of the Parallel Direct Sparse Solver for Clusters Interface is slightly better for assembled format (CSR, iparm[39] = 0) than for distributed format (DCSR, iparm[39] > 0) for the same matrices, so if the matrix is assembled on one node do not distribute it before calling cluster_sparse_solver."
But 3...5x times is not what we expect to see.  Did you check these numbers with the latest ( 2020) versions of intel mkl sparse solver for cluster?
Gennady_F_Intel
Have you had a chance to check these numbers with the latest ( 2020) versions of intel mkl sparse solver for cluster?
