7277 Discussions
How to search the eigenvalue interval of a matrix by MKL library?
HUANGK
Hi!
Hello, I want to use FEAST to solve a generalized eigenvalue problem, but I have a problem. In FEAST, the eigenvalue interval and the number of eigenvalues of the sparse matrix need to be searched. I checked the FEAST manual and did not find how to search the eigenvalue interval of the matrix. Am I missing something? Is there any built-in function in MKL to calculate the eigenvalue interval of a large sparse matrix?
Your expertise is invaluable to me, thank you for your help!
VidyalathaB_Intel
In order to use the Extended eigensolver interface in MKL, we need to pass the search interval i.e. the lower and upper bounds of the interval to be searched for eigenvalues.
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/extended-eigensolver-routines/extended-eigensolver-functionality/achieving-performance-with-extended-eigensolver.html
But the largest and smallest eigenvalues can be calculated.
In the MKL documentation, under the section > "Extended eigensolver interface to find the largest and smallest eigenvalues", there are two routines that help in calculating the largest and smallest eigenvalues.
mkl_sparse_?_ev > for standard eigenvalue problem
Reference:
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/extended-eigensolver-routines/extended-eigensolver-interfaces/ext-eigensolve-ifaces-find-large-small-eigenvalues/mkl-sparse-ev.html
mkl_sparse_?_gv > for a generalized eigenvalue problem
Reference:
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/extended-eigensolver-routines/extended-eigensolver-interfaces/ext-eigensolve-ifaces-find-large-small-eigenvalues/mkl-sparse-gv.html
Please go through the above links for full details and you can also find examples of the respective routines in the mkl folder which helps in better understanding.
Kindly let us know if this is not what you are looking for by elaborating a bit more on the issue (maybe through an example).
Vidya.
VidyalathaB_Intel
Reference:
Reference:
Vidya.
VidyalathaB_Intel
Hi Huang,
Reminder:
As we haven't heard back from you, could you please let us know if there is any update regarding your issue? Please do let us know if the provided information helps.
Vidya.
HUANGK
VidyalathaB_Intel
Hi Huang,
Thanks for accepting our solution.
As the issue is resolved we are closing this thread. Please post a new question if you need any additional assistance from Intel as this thread will no longer be monitored.
Have a Great Day!
Vidya.
