How to use SCALAPACK through MKL?
dimdol10
I have recently started to use parallel studio xe 2018, and checked installing MKL and MPI library during my installation procedure.
I am still not sure, but I hope that MKL provides SCALAPACK. However, when I call the subroutine DLASRT2, link error of unresolved external symobl occurred.
I need some helps how to utilize the SCALAPACK in the intel fortran environment through the MKL.
Any comments or helps are welcome.
mecej4
Please consult the MKL Link Line Advisor at https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor to determine the linker options to be used in order to be able to use Lapack/Scalapack routines.
Ying_H_Intel
Right, please first check if you had installed mkl scalapack library. (maybe it is not default install, you need to custom install and use Parallel studio Xe for Cluster version).  Then you can go to mkl install folder/example directory to find Scalapack sample code to see if you can build and run the them.
Ying
