7303 Discussions
I get vasp!But when run ,it gives error:./vasp: error while loading shared libraries: libmkl_p4.so: cannot open shared object file: No such file or directory
zhangwei818800
./vasp: error while loading shared libraries: libmkl_p4.so: cannot open shared object file: No such file or directory,what is the problem? Thank you !
Gennady_F_Intel
Quoting - zhangwei818800
Check this KB "Using Intel in MKL with VASP" by follow the link below
http://software.intel.com/en-us/articles/intel-math-kernel-library-intel-mkl-using-intel-mkl-in-vasp/,
may it will help you.
--Gennady
TimP
As should any reference on setting LD_LIBRARY_PATH (or use of ldconfig, if you must).
This would be another reason (or 2) for using an up to date compiler/MKL combination (fewer PATH items to set).
zhangwei818800
Quoting - tim18
But how can I set LD_LIBRARY_PATH?? What is the order? vim .bashrc??or vim bash_profile??? Please teach me in detail, my mkl is /opt/mkl/8.0/lib ,Thank you!
Gennady_F_Intel
export LD_LIBRARY_PATH=/opt/mkl/8.0/lib/em64t
