7264 Discussions
IVF 10.0.025 and MKL 9.1.022: Default Single and Double Precision Real Conflict?
brianlamm
I tried building in VS2005 a solution with two IVF projects: one an exe, and the other a dll. This is an x64 app built on an x64 host (Windows).
I use some BLAS MKL routines, one of which is "dot". I INCLUDE in a MODULE the MKL-provided source file "mkl_blas_protos.f90" found on my machine in "C:Program FilesIntelMKL9.1interfaceslas95source". That MKL-provided source file houses a single MODULE called "MKL77_BLAS", within which there is an INTERFACE called "MKL77_DOT", which provides two interfaces: one for "SDOT", and one for "DDOT" (therefore making a generic called "MKL77_DOT"). In a subsequent module (in the same source file) I include "sdot.f90" and "ddot.f90" from the same above-mentioned MKL-provided source directory. "sdot.f90" houses a PURE FUNCTION called "SDOT_MKL95", and "ddot.f90" houses a PURE FUNCTION called "DDOT_MKL95". In "sdot.f90", for example, there is a USE statement referencing "MKL77_BLAS", with an ONLY: MKL77_DOT on the same use line, and the identical USE statement is found in "ddot.f90" for "DDOT_MKL95" pure function.
Above those INCLUDEs (INCLUDE 'sdot.f90'; INCLUDE 'ddot.f90') in this subsequent MODULE of my source, I define a generic interface called "DOT", and call out "SDOT_MKL95" and "DDOT_MKL95" in that generic interface as MODULE PROCEDUREs.
It's pretty tenuous, but this combines to define a generic "DOT" in my source which disambiguates on the REAL kind type parameter of the rank one REAL arguments to "DOT". Thus are implemented the Fortran-95 wrappers to the MKL-provided BLAS routines for dot product in my source.
Here's my problem: within the MKL Fortran 77 and 95 interfaces, the working precision ("WP") is an INTEGER PARAMETER which "gets" the kind type parameter for the REAL arguments through "WP = KIND(1.0E0)" for SDOT_MKL95 and "WP = KIND(1.0D0)" for DDOT_MKL95, as well as in the interfaces for SDOT and DDOT in the generic interface MKL77_DOT. So, I *assume* the *default* working precision is based on the *default* kind type parameters *at the time of the build*.
In my source I defined two PARAMETERs: DP = KIND(1.0D0) and SP = KIND(1.0E0). Thus I additionally *assume* those parameters are set to the IVF internal representation of the kind type parameters for double and single precision reals, respectively, *at build time*.
Now, when I go into "properties" of the two projects of this solution I set the *default* single and double precisions to "8" and "16", respectively, which is double that if I just let those settings "".
When I do that, I get incorrect results (where exactly that happens I've no idea).
When I set in IVF the default single and double precisions to "4" and "8" respectively, I obtain expected and correct results.
Am I incorrect in assuming the "working precision" within the MKL routines is *set at build time*?
If that is intended behavior (non-dynamic, at build time, setting of default real precisions in MKL), I suggest the MKL documentation address it. If it's not intended behavior, then it's time for a problem report.
Brian Lamm
One thing I might add: when I set the *default* precision of INTEGERs in IVF to "8", I obtain correct results (with default single and double precision reals set in IVF to "4" and "8", respectively).
TimP
MKL has no support for the 16 byte data types of ifort. Yes, the MKL library data types are compiled in, with the S? functions taking 32-bit reals, and the D? functions taking 64-bit reals. If you have 64-bit integers in your BLAS calls, you must link with the ilp64 libraries.
brianlamm
Okay, thanks. Not very impressive, but thanks.
No support for 64-bit integers (unless one links with ilp64)? I wonder why I didn't get any result errors. Perhaps my test arrays were not large enough.
At least now I understand the problem.
Seems like a needless roadblock, however. Why not compile "double" versions (64-bit single and 128-bit double precision) and make them available?
Will MKL one day support 64-bit for S? and 128-bit for D? ?
Brian Lamm
Intel_C_Intel
We have resisted supplying 128-bit arithmetic because 1) performance and 2) naming space (qgemm for 128-bit real gemm?).
We will have, with MKL 10.0 beta, a mapping from the single precision BLAS functions to 64-bit functions in response to requests from some FEA code vendors who have code created for the Cray architecture.
Bruce
