7300 Discussions
Installation problem for the Intel ODE solver
FlyingHermes
I want to use the intel ODE solver on a linux 32-bit OS system (fedora 14 distribution)
I'm using the intel fortran compiler.
Following the installation manual, I've tried to run the examples by doing :
ifort -static iode_example_f.f -I../../include -L../../lib/ia32 -liode_ia32 -lm -o iode.out
which gave me the following error :
ld: cannot find -lm
ld: cannot find -lm
ld: cannot find -lc
ld: cannot find -ldl
ld: cannot find -lc
I know this must be a stupid problem.
Any suggestions will help!
Thx.
Gennady_F_Intel
as it seems to me you encountered with the problem described here
--Gennady
Gennady_F_Intel
--Gennady
FlyingHermes
Problem solved !!!
Thx.
The cause of the problem was indeed that, on redHat or Fedora distribution, compiling with -fast or -static causes a linker error "ld: cannot find -lm".
Solution was obtained by installing the static version of glibc, as in the link Gennady posted.
