Intel Composer 2016 Update 3 + VS2015
Lukasz_H_1
Hi guys,
I keep getting this error at the end of the Build. Please note that my code  have been developed so far using VS2010 and was automatically converted to V14 toolset.
Severity    Code    Description    Project    File    Line    Source    Suppression State
Error    MSB6003    The specified task executable "cmd.exe" could not be run. The working directory
"\mkl\tools" does not exist.
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\Platforms\Win32\PlatformToolsets\v140\ImportBefore
\Intel.Libs.MKL.v140.targets
The "mkl/tools" is however available from:
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.3.207\windows\mkl
Do you have any suggestions how could I fix it?
Shaojuan_Z_Intel
Hi Lukasz,
It looks like a setting issue in Visual Studio. Did you just update to MKL 2016 Update 3? Did it run in VS 2010 with MKL 2016 Update 3? Could you make sure the default directory in VS 2015 is pointing at "C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.3.207\windows"? Thanks!
Lukasz_H_1
No i did not just update. I've isntalled entire Parallel Studio 2016 - but w/o additional tools like IntelAdvisor, etc.
Using VS2010 also produces the same error :( although the Toolset is set to V10. Before installing  Parallel Studio 2016 everything worked fine.
The relative message for VS2010 is:
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Win32\PlatformToolsets\v100\ImportBefore\Intel.Libs.MKL.v100.targets(55,5):
Note that I've also ran mklvars.bat with arguments ia32 vs2010, but I do not know if that should be importatnt for this issue.
Regarding "default directory", can you please explain what you exactly mean by this?
One more thing, after isntalling PS2016 I noticed that inside Visual Studio there are some changes in the GUI:
a) In my main C-project properties there is additional section  "Intel Performance LIbraries". Do I have to Enable MKL here if I use it only in Fortran part of the code?
BR,
Lukasz
Lukasz_H_1
A small update.
I have "debugged" (using <Message Text="$(Variable)" Importance="high"/>) the Intel.Libs.MKL.v100.targets file, and concluded that this is the line that causes problem:
<Exec EchoOff="true" Command="mkl_link_tool.exe $(MKLArguments) 2&gt;NUL 1&gt;&quot;$(TempMklToolFile)&quot;" WorkingDirectory="$(MKLProductDir)\mkl\tools" />
The MKLArguments gives -libs -c ms_c -a ia-32
The TempMklToolFile gives C:\Users\HIRT\AppData\Local\Temp\tmp64BF.tmp
However, asking for value of MKLProductDir gives nothing !!!
BR,
Lukasz
Lukasz_H_1
Does anyone have any further suggestions?
Lukasz_H_1
All right, so what I did and what worked for me was commenting out this part:
in the following file, which by the way has already been mentioned here:
Still, I would really appreciate any comments on why such situation takes place.
BR,
Lukasz
Zhen_Z_Intel
Hi Lukasz,
There's a quick way to check if VS defined the macro of "MKLProductDir", you could check with program properties. first select use MKL in VS, in "VC++ Directories" option, select "Include Directories" to edit, select "Macro" and search $MKLProductDir.
If there's no this macro, go to VS IDE, select "View"-> "Other windows"->"Property Manager", in the window of Property manager, double click on "Microsoft.Cpp.Win32.user" within your project, select "User Macro", add a new macro $MKLProductDir. Hope it would be useful to you. Thanks.
Fiona
Lukasz_H_1
Hi Fiona,
The steps you suggested helped to get forward, so thanks you, but another error appears now:
\ImportBefore\Intel.Libs.MKL.v100.targets(55,5): error MSB3073:
The command "mkl_link_tool.exe -libs -c ms_c -a ia-32 2>NUL 1>"C:\Users\HIRT\AppData\Local\Temp\tmp5134.tmp""
exited with code 1.
The MKLProductDir variable points to: C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.3.207\windows
Do you have any further suggestions? :)
Zhen_Z_Intel
Hi Lukasz,
The mkl_link_tool.exe is used for generating link lines according to your system environment & compiler situation. The reason you get null return is that you give it wrong command input. There's no architecture(-a) call ia-32, it should be ia32, please modify command to
mkl_link_tool.exe -libs -c ms_c -a ia32
In Intel.Libs.MKL.v100.targets, from line 38-51, describes how VS IDE set commands for mkl_link_tool.exe. And you may notice the 41& 42 lines:
<_MKLArgPlatform>ia-32</_MKLArgPlatform>
<_MKLArgPlatform Condition="$(MKLMNewArgFormat) == 1">ia32</_MKLArgPlatform>
The arch is set as ia-32 by default, but if the macro $(MKLMNewArgFormat) equals to 1, it would be set as ia32. I think you may lack of that macro.... For your problem, seems your VS2010 lost all macro relevant to MKL, I am not sure if you fixed this problem, how many other problem caused by macro would appear. My advice is, you may could uninstall the whole software, and try to install latest IPS windows package integrated on VS IDE.
Fiona
