7302 Discussions
MKL ERROR: Parameter 8 was incorrect on entry to DSYEV
Charulatha_V_
Hi, I'm trying to use the lapack and blas libraries. I tried a simple example program that uses DSYEV. I get the following error on running the program: MKL ERROR: Parameter 8 was incorrect on entry to DSYEV. I issued the following commands to load the modules and compiled them.
>module load intel/2012.0.032
>ifort -O3  example.f -lmkl_intel_ilp64 -lmkl_core -lmkl_sequential  -lpthread -lm
I would appreciate any help in solving this problem.
thanks,
charu.
The example.f program is :
       program main
       implicit none
*     .. Parameters ..
      INTEGER          N
      PARAMETER        ( N = 5 )
      INTEGER          LDA
      PARAMETER        ( LDA = N )
      INTEGER          LWMAX
      PARAMETER        ( LWMAX = 1000 )
*     .. Local Scalars ..
      INTEGER          INFO, LWORK
      integer :: i, j
*     .. Local Arrays ..
      DOUBLE PRECISION A( LDA, N ), W( N ), WORK( LWMAX )
      DATA             A/
     $  1.96, -6.49, -0.47, -7.20, -0.65,
     $ -6.49,  3.80, -6.39,  1.50, -6.34,
     $ -0.47, -6.39,  4.17, -1.51,  2.67,
     $ -7.20,  1.50, -1.51,  5.70,  1.80,
     $ -0.65, -6.34,  2.67,  1.80, -7.10
*     .. External Subroutines ..
      EXTERNAL         DSYEV
      EXTERNAL         PRINT_MATRIX
*     .. Intrinsic Functions ..
      INTRINSIC        INT, MIN
*     .. Executable Statements ..
      WRITE(*,*)'DSYEV Example Program Results'
      LWORK = LWMAX
      CALL DSYEV( 'Vectors', 'Upper', N, A, LDA, W, WORK, LWORK, INFO )
      IF( INFO.GT.0 ) THEN
         WRITE(*,*)'The algorithm failed to compute eigenvalues.'
         STOP
      END IF
*     Print eigenvalues.
      CALL PRINT_MATRIX( 'Eigenvalues', 1, N, W, 1 )
*     Print eigenvectors.
      CALL PRINT_MATRIX( 'Eigenvectors (stored columnwise)', N, N, A,
     $                   LDA )
      STOP
      END
*     End of DSYEV Example.
*     Auxiliary routine: printing a matrix.
      SUBROUTINE PRINT_MATRIX( DESC, M, N, A, LDA )
      CHARACTER*(*)    DESC
      INTEGER          M, N, LDA
      DOUBLE PRECISION A( LDA, * )
      INTEGER          I, J
      WRITE(*,*)
      WRITE(*,*) DESC
      DO I = 1, M
         WRITE(*,9998) ( A( I, J ), J = 1, N )
      END DO
 9998 FORMAT( 11(:,1X,F6.2) )
      RETURN
      END
TimP
Apparently, you are using default (32-bit) integers, but you have selected the ilp64 (64-bit integer) library.  The lp64 library is the one which expects default integers.
Charulatha_V_
Hey Thanks, That fixed the problem !
