Non-standard usage of sycl::abs
nmnobre
In poisson_impl.hpp there are four usages of double sycl::abs(double) which is not defined in the SYCL standard.
Would it be possible to instead use double sycl::fabs(double)which is equivalent but standard compliant?
See also this issue in the intel/llvm GitHub repo.
Cheers,
-Nuno
VarshaS_Intel
Thank you for your patience.
The issue raised by you has been fixed in version 2023.2 and it is released now. Please find the below link to download the latest Intel MKL Toolkit or you can also download the complete Intel Base Toolkit.
https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl-download.html
https://www.intel.com/content/www/us/en/developer/tools/oneapi/base-toolkit-download.html?operatingsystem=linux&distributions=offline
Thanks & Regards,
Varsha
Alina_E_Intel
Hi @nmnobre,
Thank you for pointing on this issue! Yes you are right, sycl::fabs should be used in poisson_impl.hpp. We will implement the fix in the future updates.
Also thank you for coming on our community forum, please, let us know if you have any oneMKL-related questions.
Alina
VarshaS_Intel
Thanks & Regards,
Varsha
