OpenMP vs trigonmetric transforms
NIcolas_T_
!$omp parallel   private(iy,iz,bx,by) shared(ll,nn,mm,b,im1)
!$omp do
  do iz = 1,ll
    do iy = 1,nn
        bx=.0
        by=.0
        !fetch data
        bx(1:mm)=real(b(1:mm,iy,iz,ik))
        by(1:mm)= aimag(b(1:mm,iy,iz,ik))
        !compute forward sine transform
        call dst_fwd(im1,bx(0:im1))
        call dst_fwd(im1,by(0:im1))
       !set data
        b(1:mm,iy,iz,ik) =cmplx( bx(1:mm),by(1:mm))
    enddo
  enddo
!$omp end do
!$omp end parallel
The code snippet above crashes on runtime with no error message when I put OpenMP commands around the the two loops in order to compute Sine Transforms (subroutine dst_fwd ) in parallel.
Does anyone could give me a hint what may cause the program to crash?
Nicolas
TimP
I suspect we would need a full working example.
