OpenMP with MKL - Get Thread Num
Raphael_P_
When using OpenMP I can get the thread num by using:
omp_get_thread_num()
However when using it with MKL the, the command doesn't work. Is there ano MKL command which replaces this?
Thank you,
Raphael
SergeyKostrov
Valued Contributor II
Here is a simple example how I use it:
    #if ( defined ( _RTPRAGMAOMP_PARALLEL ) )
    #pragma omp parallel
    #endif
     RTinumber iId = OmpGetThreadId();
     #ifdef _RTMATRIXSETCORE_DIAGNOSTICS
     CrtPrintf( RTU("ThreadID=%2ld\n"), ( RTINT )iId );
     #endif
     RTiterator i;        // VR: Vectorized
     for( i = iStart[iId]; i < iEnd[iId]; i += 1 )
      ptR = ptA + ptB;
     CrtSfence();
Note: OmpGetThreadId is a macro wrapper for omp_get_thread_num function.
SergeyKostrov
>>...However when using it with MKL the, the command doesn't work... OpenMP function omp_get_thread_num() should work in a parallel region(s) and it doesn't matter if MKL is used or not used. Could you post a piece of codes for review?
SergeyKostrov
    #endif
     #endif
      ptR = ptA + ptB;
     CrtSfence();
Gennady_F_Intel
You may try to use verbose mode to take the OpenMP thread number of the calling thread. pls see MKL User's Guide for details.
