PARADISO Compile Error
Bradley_R_
I am trying to use PARADISO from the MKL library, however, I cannot compile my program because of the following C2059 syntax error '(' on Line 71 of mkl_paradiso.h
Has anyone else had this problem?
I am using VS2015, the same error occurs is ILP64 is on or off. I have an intel i7-4720HQ chip in a Razer Laptop, running windows 8.
compiling debug x64
mecej4
It would help to have the source code that you tried to compile, and information about MKL version, C compiler used and C compiler options used.
Alternatively, you could yourself use the compiler's /E flag to show the output of the preprocessor and examine the line that caused the problem, in particular whether the output line (or group of lines) have mismatched parentheses.
Gennady_F_Intel
Bradley, let's try to start since the one of pardiso C example which you can find from "mkROOTl\examples\solverc\source\" folder. Do you see the same problem with these examples?
Bradley_R_
Hi Gennady,
Do you know which of the samples uses Pardiso? I can get this sample: sexample_sparse_c.c to compile & run with no problems.
I'm using the vc140 compiler through visual studio 2015. I'm using the MKL 11.3
thanks!
Bradley
mecej4
Look in the folder ...\mkl\examples\solverc\source . There will be about half-a-dozen files with names starting with "pardiso".
