7302 Discussions
PARDISO: ERROR during symbolic factorization: -3 (reordering problem)?
SAL_AHM
I am using the pardiso direct solver to solve the system of equation obtained from finite element method applied on nonlinear PDE. I will solve my problem for high number of matrix size (small mesh size) but now I discus only small number of size to fixed the code problems.
My data is in CRS (or CSR)  defined in three vectors _id, _ik, _sk and right hand side in vector f. I applying the copy command to transform its into array as:
MKL_INT n = f.size();
MKL_INT nnz = _sk.size();
MKL_INT m = _id.size();
 ia[m];
copy(_id.begin(), _id.end(), ia);
MKL_INT ja[nnz];
copy(_ik.begin(), _ik.end(), ja);
double a[nnz];
copy(_sk.begin(), _sk.end(), a);
When I run the code it gives the error:
"*** Error in PARDISO  (        reordering_phase) error_num= -180
*** error PARDISO: reordering, symbolic factorization
=== PARDISO: solving a real nonsymmetric system ===
1-based array indexing is turned ON
PARDISO double precision computation is turned ON
User provided fill-in reducing permutation is turned ON
Summary: ( reordering phase )
Times:
Time spent in calculations of symmetric matrix portrait (fulladj): 0.000040 s
Time spent in reordering of the initial matrix (reorder)         : 0.000000 s
Time spent in symbolic factorization (symbfct)                   : 0.000705 s
Time spent in allocation of internal data structures (malloc)    : 0.000367 s
Time spent in matching/scaling                                   : 0.000001 s
Time spent in additional calculations                            : 0.000042 s
Total time spent                                                 : 0.001155 s
Statistics:
Parallel Direct Factorization is running on 48 OpenMP
< Linear system Ax = b >
             number of equations:           95
             number of non-zeros in A:      2364
             number of non-zeros in A (%): 26.193906
             number of right-hand sides:    1
< Factors L and U >
             number of columns for each panel: 128
             number of independent subgraphs:  0
< Preprocessing with input permutation >
             number of supernodes:                    51
             size of largest supernode:               45
             number of non-zeros in L:                2077
             number of non-zeros in U:                88
             number of non-zeros in L+U:              2165
Salman Ahmad: 4
ERROR during symbolic factorization: -3make: *** [../ICC_default.mk:78: run] Error 1"
I noted one point, my number of nonzero is 2365 but here "number of non-zeros in A:      2364"
For code to past here for this specific example, n= 95, m = 96, nnz = 2365 and
ia[m] = {values printed from ia};
ja[nnz] = {values printed from ja};
a[nnz] = {values printed from a};
b[m] = {values printed from b};
The code is in the attachment, please any suggestion to solve this problem!
VarshaS_Intel
Thanks for the details.
Please find the modified attached zip file with code(code.txt) where we are able to get the results without any errors. Also, I have attached the results of the code(result.txt)
And, also you can find examples of the PARDISO in the following path (/opt/intel/oneapi/mkl/latest/examples/c/sparse_directsolvers/source)
Could you please try and let us know if you facing any errors?
Thanks & Regards,
Varsha
VarshaS_Intel
Could you please let us know the OS details(linux/windows/macOS) and Intel oneAPI version you are using?
And also, Could you please let us know the compilation options/ interface being used so that we could investigate more?
Thanks & Regards,
Varsha
SAL_AHM
My OS is linux  and oneAPI version is 2023.0.0.
I am trying on icpc, also try icpx but still error.
VarshaS_Intel
Thanks & Regards,
Varsha
VarshaS_Intel
Glad to know that your issue is resolved. Thanks for accepting our solution. This thread will no longer be monitored by Intel. If you need additional information, please start a new question.
Thanks & Regards,
Varsha
