Parallel pardiso solve step
Jens_E_
Refering to the iparm[24] (0-indexed) parameter: https://software.intel.com/en-us/mkl-developer-reference-c-pardiso-iparm-parameter#IPARM24
Is it really the case that the fwd/backward steps are not parallel as default (=0) ?
Jens
Gennady_F_Intel
Jens, this is issue into documentation. We will fix it into one of the future updates.
Gennady_F_Intel
Here is the  correct version of description:
iparm[24]
0*  -- Intel ® MKL PARDISO uses the following strategy for parallelizing the solving step:  In the case of the one right-hand side, the parallelization will be performed by partitioning the matrix. Otherwise, the parallelization will be over the right-hand sides.
1  --   Intel ® MKL PARDISO uses the sequential forward and backward solve.
2  --  Independent from the number of the right-hand sides, Intel ® MKL PARDISO uses the parallel algorithm based on the matrix partitioning.
This feature is available only for in-core Intel MKL PARDISO (see iparm[59]).
