Pardiso-OOC solver
mma1
Hi, All,
Does anyone have a success of PARDISO-OOC solver? If so, do you needa "pardiso-ooc.cfg" file to make it work? Can you post a smaple of "pardiso-ooc.cfg" file?
Many thanks
Ming
Sergey_Solovev__Inte
Hi, Ming,
Cfg-file "pardiso_ooc.cfg" should be located in the working directory. Its content should be as in example:
MKL_PARDISO_OOC_PATH = ./tmp
MKL_PARDISO_OOC_MAX_CORE_SIZE = 300
MKL_PARDISO_OOC_KEEP_FILE = 0
On the other hand, you can set these variablesas environmental variables:
Lnx:
export MKL_PARDISO_OOC_PATH = ./tmp
export MKL_PARDISO_OOC_MAX_CORE_SIZE = 300
export MKL_PARDISO_OOC_KEEP_FILE = 0
or Win:
set MKL_PARDISO_OOC_PATH = ./tmp
set MKL_PARDISO_OOC_MAX_CORE_SIZE = 300
set MKL_PARDISO_OOC_KEEP_FILE = 0
