Paths of MKL/icc on Mac OS X
reiko_nakajima
I have (hopefully) a simple question.
I have just installed MKL (m_mkl_p_10.0.3.020) on my Mac Pro, but the header files and the libraries are not showing up at the usual convenient site (/usr/local/lib, or even /opt/intel/), but are in directories such as:
/Library/Frameworks/Intel_MKL.framework/Versions/Current/Libraries/em64t/ ... etc.
I do have icc installed, but I've added the icc directory to my search path (/opt/intel/cce/10.1.014/bin/) to make it work, so I think my icc setup is incorrect as well. Could someone tell me what I'm missing?
Thanks in advance,
Reiko Nakajima
TimP
Your icc installation is the normal default. You should have scripts in that directory which can be sourced to set the paths. As MKL is being incorporated into the compiler installation scheme, in the next major release, the compiler and MKL paths would be set in one step.
reiko_nakajima
Thanks for your response. I see--so I need to source iccvars.csh (or .sh) so that the path, etc., are set; and if I understand correctly, I will need to create links in the LD_LIBRARY_PATH that points to where the MKL libraries currently are, as well as specifically point to the MKL header directories when I compile. Thanks, Reiko
TimP
The new moderator's post tells how to get the new beta version of integrated compiler/mkl, so you could give feedback on whether the path setting is indeed more convenient:
http://software.intel.com/en-us/forums/showthread.php?t=60130
