Problem with MKL in eclipse
hanxc
Hello, I'm trying to use gels subroutine in mkl to solve a least square question. I installed mkl according to the userguide and I tested the example gels.f90 using
ifort gels.f90 -L$MKLPATH -I$MKLINCLUDE -I$MKLINCLUDE/32 -lmkl_lapack95
-Wl,--start-group $MKLPATH/libmkl_intel.a
$MKLPATH/libmkl_intel_thread.a $MKLPATH/libmkl_core.a -Wl,--end-group
-liomp5 -lpthread
But I can't build this example in eclipse + photran plugin.
How can I setup the linker option in eclipse?
Could anybody please help me with that?
Thanks~~
Gennady_F_Intel
Quoting - hanxc
-liomp5 -lpthread
Thanks~~
xhan, what compiler version do you use?
Artem_V_Intel
Quoting - hanxc
-liomp5 -lpthread
Thanks~~
IMHO the simplest way to build the MKL example using Eclipse IDE is using Makefile-based Photran project. For projects with automatically managed makefiles you should use Project>Properties>Fortran Build>Settings dialog page. At this page you should have ability to change Compiler and Linker options.
Art
