Routines mkl_?tppack and mkl_?tpunpack
Eugene_S_1
The documentation reads the following names for these routines (C interface): LAPACKE_mkl_?tppack and LAPACKE_mkl_?tpunpack. However, these names are not defined in the mkl_lapacke.h header file. Instead, LAPACKE_?tppack and LAPACKE_?tpunpack (with no mkl) are defined. If I use these names I get an "unresolved external" error on linking. Manual modification of the aforementioned header file solves the problem. I suggest this header file be fixed accordingly.
Gennady_F_Intel
thanks Eugene, we will fix that asap.The workaround you suggested, is also correct.
Gennady_F_Intel
Eugene, the latest 11.3.3 contains the fix of the problem. Here is the mkl_lapacke.h  from 11.3.3 :
LAPACK_DECL
lapack_int LAPACKE_mkl_stppack( int matrix_layout, char uplo, char trans, lapack_int n,
                                float* ap, lapack_int i, lapack_int j, lapack_int rows,
                                lapack_int cols, const float* a, lapack_int lda );
lapack_int LAPACKE_mkl_stpunpack( int matrix_layout, char uplo, char trans, lapack_int n,
                                  const float* ap, lapack_int i, lapack_int j, lapack_int rows,
                                  lapack_int cols, float* a, lapack_int lda );
and etc ......
