7303 Discussions
Segmentation Fault in poisson solver (mixing C & C++ Problem)
zudol0104
Hello
I'm trying to embed MKL's Poisson solver in my own C++ code. I even succeeded in building & running the example included in the MKL Library, but the problem is that when I try to use it in my C++ code, I get a Segmentation Fault.
My code consists of 3 files.
        - d_Helmholtz_3D_c.h
        - d_Helmholtz_3D_c.c
        - main.cc
Where , "d_Helmholtz_3D_c.c " is a slight modification of the example file.
        int main() -> void poisson()
"d_Helmholtz_3D_c.h" is as follows
#ifndef __D_HELMHOLTZ_3D_C_HH
#define __D_HELMHOLTZ_3D_C_HH
void poisson();
#endif
"main.cc" is as follows
#include <iostream>
extern "C" {
#include "d_Helmholtz_3D_c.h"
int main() {
using std::cout;
using std::endl;
cout << "Main" << endl;
poisson();
return 0;
CMakeLists.txt is as follows
cmake_minimum_required (VERSION 3.16.2)
enable_testing()
set(CMAKE_C_COMPILER icc)
set(CMAKE_CXX_COMPILER icpc)
project (oneMKL_Example)
set(MKL_ROOT /my/dir/intel-oneAPI/mkl/latest/)
list(APPEND CMAKE_MODULE_PATH "MKL_ROOT/lib/cmake")
find_package(MKL CONFIG REQUIRED)
add_executable(myapp main.cc)
target_link_libraries(myapp PUBLIC poisson)
add_library(poisson d_Helmholtz_3D_c.c)
# add_executable(myapp d_Helmholtz_3D_c.c)
target_compile_options(myapp PUBLIC $<TARGET_PROPERTY:MKL::MKL,INTERFACE_COMPILE_OPTIONS>)
target_include_directories(myapp PUBLIC $<TARGET_PROPERTY:MKL::MKL,INTERFACE_INCLUDE_DIRECTORIES>)
target_link_libraries(myapp PUBLIC $<LINK_ONLY:MKL::MKL>)
The mkl version checked with mkl_get_version() is as follows.
Major version: 2021
Minor version: 0
Update version: 2
Product status: Product
Build: 20210312
Platform: Intel(R) 64 architecture
Processor optimization: Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors
Why on earth would a segmentation fault occur?
ShanmukhS_Intel
Thanks for sharing the detailed steps. It is always recommended to use the latest version of oneMKL. Hence, could you please try the latest oneMKL (2023.2), and let us know if the issue persists? We are looking into your issue. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi June,
We could see a segmentation fault occurring at the "d_commit_Helmholtz_3D" step of the d_Helmholtz_3D_c.c file.
Could you please add the -DMKL_ILP64 in the compile flag and let us know if the issue persists?
Shanmukh.SS
zudol0104
I added -DMKL_ILP64 in the compile flag and it works
ShanmukhS_Intel
Hi June,
It’s great to know that the issue has been resolved, in case you run into any other issues please feel free to create a new thread.
Shanmukh.SS
