Simple fft question
perco754
I am trying to use the fft routine(for the first time), cfft1dc but it seems not to work the way I thought it should.
Here is the code:
void fft_init(INTEGER N) {
#ifdef WIN32
wsave = FLOAT_ALLOC(3*N);
#endif
void fft_deinit() {
#ifdef WIN32
FLOAT_FREE(wsave);
#endif
void fft(FLOAT* real_input, FLOAT* imag_input, FLOAT* real_output, FLOAT* imag_output, INTEGER N) {
cblas_scopy(N, real_output, 1, real_input, 1);
cblas_scopy(N, imag_output, 1, imag_input, 1);
cfft1dc(real_output, imag_output, N, 0, wsave);
cfft1dc(real_output, imag_output, N, -1, wsave);
As I understood from the doc, wsave is an output parameter if isign=0 and if isign!=0,
wsave contains the FFT coeff initialized on a prevoius call with isign=0.
So, where do I miss the thing?
Regards, Per
