Stack trace terminated abnormally
felipin85
Hi everybody! I'm using Intel Fortran Compiler for Linux, Ubuntu 10.10 64 bits. I have a problem with a subroutine, I get the following message:
Comenzamos a calcular los desplazamientos. Ten paciencia
Tiempo de calculo = 0.0199999999999996 segundos.
SALI DE LAS ECUACIONES DE MINDLIN
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image PC Routine Line Source
Stack trace terminated abnormally.
In the execute of the subroutine EcuacionesMindlinEmpotradoTodo.f90, the subroutine call to SPARSE, SPARSE using mkl_dss,when the main program ends appears the bug. Could someone explain where I have the bug? Thanks.
Felipe Rodrguez
mecej4
You did not post all the files needed to build the program. The following routines are missing:
REORDENACIONGIROSDESPLAZAMIENTOS
PASO
GENERACIONMALLADO
CONDICIONCONTORNO
VECTORCARGAS
REORDENACIONSIMPLE
MOMENTOSMOD
Please also state the version of the compiler (ifort -V), the compilation options used, and supply any data needed to run the program.
mecej4
Your program requires more stack space than the default. Lookup "ulimit" for how to allocate stack limits. You will also need to use the "-traceback" compiler option to help with debugging your program. Other useful information is provided in this link:
determining-root-cause-of-sigsegv-or-sigbus-errors
felipin85
First, Mecej4 very thanks for your help. But, I have a question, how change the option ulimit?
In the link talks of change bash, but, I don't know if It is change the file bashrc or write in the terminal.
Sorry for the inconvenience
mecej4
Putting in the ulimit stack option in .bashrc makes the option apply to every Bash session; running the command in a shell makes it apply only to that session. Take your pick.
You may want to consider two changes: (i) Do not use automatic allocation on the stack for very large arrays; (ii) remove or comment out the Gnuplot calls and messages until your program is working correctly.
felipin85
Sincerely, thank you very much. I will do as suggested.
