7302 Discussions
There is no matching specific subroutine for this generic subroutine call: oneAPI seems more fussy
Peter0000
In compiling some old code, I find oneAPI iFort is much stricter about interfaces e.g
error #6285: There is no matching specific subroutine for this generic subroutine call.   [GETRF]
USE F95_PRECISION
USE LAPACK95
etc
REAL(DP)                    :: M(ng,ng)
INTEGER [,TARGET] :: indx(ng)
INTEGER                     :: info
etc
call GETRF(M,indx,info)
While many were fixed by simply changing "info" from INTEGER I4B (my past error)  to INTEGER, the above was not fixed.
Adding TARGET to indx did not help
Peter0000
My apologies. While I have not found put why my legacy code fails to compile,  my attempts to replicate it the fault fail. It does not even care if TARGET is present.
o the attached works
I may leave the question open in case I learn anything when or if I find my issue.
Peter0000
Peter0000
Solved.  I had a link to an local copy of lapack95.f90,  an old "patch" to make MKL work.
Removing it fixes it.
SantoshY_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
