7277 Discussions
Unable to build scipy with mkl on ubuntu 12.04
aurora1625
I am trying to build numpy and scipy on 64-bit Ubuntu 12.04 with Intel MKL.
I have installed all the prerequisites. The INTEL C++ complier and the Fortran compiler verision are all 2011 sp1 10.319 and MKL is the version within it.
I am following the installation instruction fromINTEL's website.
I have successfully build and installed numpy.
When building scipy I encounted the problem as follows:
error: could note create '/usr/local/lib/python2.7/dist-packages/scipy': Permission denied
when I try to put sudo in front of the install line, I got:
numpy.distutils.fcompiler.CompilerNotFound: intelem: f90 nor f77
Could anyone help me?
Thanks!
Ying_H_Intel
Hi Aurora1625,
Do you mean you got the error at the step with the command
Compile and install SciPy with the Intel Compilers: (On 64-bit platforms replace "intel" with "intelem")
sodu $pythonsetup.pyconfig--compiler=intel--fcompiler=intelbuild_clib--compiler=intel--fcompiler=intelbuild_ext--compiler=intel--fcompiler=intelinstall
Ying
VipinKumar_E_Intel
Can you also find the Intel Fotran compiler in your PATH?
--Vipin
Pierre_E_
Hey I have the same issue: I am trying to install Numpy/Scipy with the instructions given on this webpage: http://software.intel.com/en-us/articles/numpyscipy-with-intel-mkl . So the site.cfg file and the intel.py files have been modified according to the specifications given by the webpage. I encounter the same issue on installing Numpy and Scipy: When installing Numpy with the command given: sudo python setup.py config --compiler=intelem build_clib --compiler=intelem build_ext --compiler=intelem install the installation process seams to work well until this error shows up: creating /usr/local/lib/python2.7/dist-packages/numpy error: could not create '/usr/local/lib/python2.7/dist-packages/numpy': Permission denied So I passed the command as a super user: sudo python setup.py config --compiler=intelem build_clib --compiler=intelem build_ext --compiler=intelem install but now there is another error: compile options: '-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/include -I/usr/include/python2.7 -c' icc: _configtest.c sh: 1: icc: not found sh: 1: icc: not found failure. removing: _configtest.c _configtest.o Traceback (most recent call last): File "setup.py", line 214, in setup_package() File "setup.py", line 207, in setup_package configuration=configuration ) File "/home/pierre/Téléchargements/numpy-1.6.2/numpy/distutils/core.py", line 186, in setup return old_setup(**new_attr) File "/usr/lib/python2.7/distutils/core.py", line 152, in setup dist.run_commands() File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands self.run_command(cmd) File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command cmd_obj.run() File "/home/pierre/Téléchargements/numpy-1.6.2/numpy/distutils/command/build_clib.py", line 62, in run self.run_command('build_src') File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command self.distribution.run_command(command) File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command cmd_obj.run() File "/home/pierre/Téléchargements/numpy-1.6.2/numpy/distutils/command/build_src.py", line 152, in run self.build_sources() File "/home/pierre/Téléchargements/numpy-1.6.2/numpy/distutils/command/build_src.py", line 163, in build_sources self.build_library_sources(*libname_info) File "/home/pierre/Téléchargements/numpy-1.6.2/numpy/distutils/command/build_src.py", line 298, in build_library_sources sources = self.generate_sources(sources, (lib_name, build_info)) File "/home/pierre/Téléchargements/numpy-1.6.2/numpy/distutils/command/build_src.py", line 385, in generate_sources source = func(extension, build_dir) File "numpy/core/setup.py", line 696, in get_mathlib_info raise RuntimeError("Broken toolchain: cannot link a simple C program") RuntimeError: Broken toolchain: cannot link a simple C program Note that this output indicates that icc cannot be found, but it is well installed on the computer and in the PATH environment variable and without the super user things seems to compile... The same issue comes up with scipy, the files cannot be copied to /usr/local/lib/python2.7/dist-packages/ (I guess this is what the sciprt intend to do) because of denied permission. But when I pass the install command in super user mode I get this error: numpy.distutils.fcompiler.CompilerNotFound: intelem: f90 nor f77 Though icc and ifort is installed, and in use, because when I execute the install command as normal user I can see everything compiling! It seems that everything is compiled and ready to use but when the installed script tries to copy the compiled files to the shared python modules in /usr/local/lib/python2.7/dist-packages/ it needs super user permission. And apparently when running the command as super user the compilers can't be no longer found. System decription: HP Z800 workstation with Intel® Xeon(R) CPU X5675 @ 3.07GHz × 12 Running on Ubuntu 12.04 icc -> composer_xe_2011_sp1.10.319 ifort -> composer_xe_2011_sp1.9.293 MKL -> composer_xe_2011_sp1.11.339 Running the command ifort and icc show that they are indeed installed. I am ready to give you any information you need about the system used if you need it! Thank you for your help! Regards, Pierre
Ying_H_Intel
HI Pierre, I saw you have shared some comments under the article is the problem resolved by yourself? Best Regards, Ying
Ethan_B_
On Xubuntu 12.10, this issue is solved by linking ifort and icc in /usr/bin. Apparently, as @Pierre noticed, these files can't be found by the root account when you do "sudo python setup.py config ..." since they're usually installed to /opt. But the root account does look at /usr/bin, so put the links there.
TimP
As your sudo command opens a new shell, you would need to set the same compiler environment in that shell as in your user shell, in order to build normally.
Ying_H_Intel
Hi
I summarize the issue here so more users may clear about the problem:
The error "Permission denied" because non-super user.  if use
icc/ifort environment can be set up  because sudo don't recognize the 'source source /opt/intel/composer_xe_2013_sp1.2.144/bin/iccvars.sh intel64".
So user can use root to build the numpy and scipy if possible.
Or either Pierre's solution
cipy should be done in two steps:
First to build (with intelem instead of intel for 64 bits processors):
python setup.py config --compiler=intel build_clib --compiler=intel build_ext --compiler=intel
Then install:
sudo python setup.py install
Same for Scipy.
or Ethan's solution:
Ying
