7302 Discussions
Why does LAPACKE_dormqr require double length of input array b?
Wu__Wentao
Using QR factorization to solve a linear least square problem requires three functions:
LAPACKE_dgeqrf for QR factorization matrix A = Q*R,
LAPACKE_dormqr for calculation of c = QT*b, and
dtrsm for solution of R*X = c.
The declaration of the second function, LAPACKE_dormqu, is
lapack_int LAPACKE_dormqr( int matrix_order, char side, char trans, lapack_int m, lapack_int n, lapack_int k, const double* a, lapack_int lda, const double* tau, double* b, lapack_int ldb); .
The question is array b must hold double elements than b should. Here is an example:
//Least_square_test.cpp
#include
#include
#include
#include
using namespace std;
void print(double*, int, int = 12);
int main(){
int matrix_order = LAPACK_COL_MAJOR;
lapack_int info, m(3), n(2), lda(3);
double a[6] = {0,1,2,1,1,1};
double tau[2] = {0.0,0.0};
info = LAPACKE_dgeqrf(matrix_order, m, n, a, lda, tau)); // It works well here.
lapack_int k(2), ldb(3);
const int dim_b = 6; //Note that it must double length of b!
double b[dim_b] = {0,1.1,2};
if(LAPACKE_dormqr(matrix_order, 'L', 'T', m, n, k, a, lda, tau, b, ldb)) // This will result right answer here!
cerr<<"Something wrong in Q'*B multiplication!"<
else
cout<<"Succeed in Q'*B multiplication!"<
cout<<"a = "<
print(a,6);
cout<<"tau = "<
print(tau,2);
cout<<"b = "<
print(b,dimb);
cout<
return 0;
void print(double *a, int N, int width){
for(int i = 0; i != N; ++i)
cout<<
cout<
I compile it with Intel icpc (ICC) 12.1.3 20120212 with least MKL in Ubuntu 10.04 platform, and it display the right answer b = -2.28079 0.0365148 -0.0816497.
But if I set dim_b = 3, the answer is incorrect: -2.28079 0.0879783 -0.0323584, and const array tau is also changed.
Any comments are welcome and thank you for your answers!
David Wu
TimP
You could study the open source and see how the arrays are used.
Ying_H_Intel
Hi David,
I haven't tried the code with exact icc 12.1.3 in Ubuntu 10.04 platform. But one of parameter of LAPACKE_dormqr(matrix_order, 'L', 'T', m, n, k, a, lda, tau, b, ldb)) seems be given wrong value. So you have to setting b=m*n=6.
Here m, n is not related to A, but the B in QT B ( or C in MKL manual:
m
INTEGER. The number of rows in the matrix C (m 0).
n
INTEGER. The number of columns in C (n 0).
In your test case, the B is 1 column. So if you change
const int dim_b =3; //Note that it must double length of b!
n=1;
You will get correct value: 2.28079 0.0365148 -0.0816497.
Ying
