Xcode config scheme for composer 2015
steve_o_
I'm successfully using composer 2015 Fortran via command line but I'm attempting to integrate into Xcode 5 (Xcode 6.x is not working yet)
I'm using one of the demo programs to test compilation and linking with libs (using random no generators , mersenne twister etc)
If I try to run in Xcode I get the following linker error after setting the DYLD_LIBRARY_PATH in Xcode
Undefined symbols for architecture x86_64:
  "_vdrnguniform_", referenced from:
      _MAIN__ in iforta5IzJW.o
  "_vsldeletestream_", referenced from:
  "_vslnewstream_", referenced from:
ld: symbol(s) not found for architecture x86_64
I can compile and run from the command line using the following
ifort mkl_vsl_uniform.f90   $MKLROOT/lib/libmkl_blas95_ilp64.a $MKLROOT/lib/libmkl_intel_ilp64.a $MKLROOT/lib/libmkl_core.a $MKLROOT/lib/libmkl_intel_thread.a   -o mkl_vsl_uniform
Removing $MKLROOT/lib/libmkl_intel_ilp64.a from the compilation gives the same error. So my question, is my DYLD_LIBRARY_PATH set correctly or am I missing a linker setting somewhere? The following is my current command line env
      Intel(R) Math Kernel Library (Intel(R) MKL) Link Tool v4.0
Output
Compiler option(s):
 -I/opt/intel/composer_xe_2015.0.077/mkl/include
Linking line:
 -L/opt/intel/composer_xe_2015.0.077/mkl/lib -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -openmp -lpthread -lm
Environment variable(s):
export DYLD_LIBRARY_PATH=/opt/intel/composer_xe_2015.0.077/mkl/../compiler/lib:/opt/intel/composer_xe_2015.0.077/mkl/lib:$DYLD_LIBRARY_PATH;
VipinKumar_E_Intel
Is it possible to attach your xcode project file?
steve_o_
Hi Vipin
Just a simple test, just trying to verify that my Xcode setup is correct so that MKL is useable
Is it possible to configure the debugger in xcode?, it's a bit of a pain relying on print statements for debug
please find attached sample xcode 5 project, I have xcode 6.1 as well but I don't think that is supported yet
regards
Steve
steve_o_
In case anyone else has this question in future. I found an old article on the Intel site for Xcode 3
https://software.intel.com/en-us/articles/quick-link-intel-mkl-in-xcode-ide-a-fortran-sample
Just tried it with ifort 15 and Xcode 5.1.1 and it worked for me
