fatal error: 'mkl.h' file not found
A_P
Hi, this the first time I’m trying to run C++ code in command line and I need to use mkl.h library. I have downloaded the oneAPI base toolkit but I don't know how to make the command line knows the downloaded library.
I am using terminal on macos system.
VidyalathaB_Intel
You can follow the link line advisor suggestions for successfully compiling and linking your application with MKL.
Link Line advisor tool helps you to get the compiling and linking options with respect to your environment.
Here is the link for the link line advisor tool:
https://www.intel.com/content/www/us/en/developer/tools/oneapi/onemkl-link-line-advisor.html?wapkw=link%20line%20advisor#gs.pzy22d
Another way is to simply include the -qmkl option in your command
Reference link:
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-macos-developer-guide/top/linking-your-application-with-onemkl/linking-quick-start/using-the-qmkl-compiler-option.html
icpc -qmkl <filename.cpp>
(icpc is the Intel compiler for C++ language and you can get this by downloading oneAPI HPC Toolkit)
Before this, you need to run the setvars.sh script file(command: source /opt/intel/oneapi/setvars.sh) to set the environment variables
https://www.intel.com/content/www/us/en/develop/documentation/onemkl-macos-developer-guide/top/getting-started/setting-environment-variables.html
Let us know if you face any issues.
Vidya.
VidyalathaB_Intel
Reminder:
Could you please provide us with an update regarding the issue? If it is resolved, please confirm whether we can close this thread from our end.
Vidya.
VidyalathaB_Intel
As we haven't heard back from you, we assume that your issue is resolved with the provided information in the previous posts and hence closing this thread. Please post a new question if you need any additional information from Intel as this thread will no longer be monitored.
Vidya.
