7300 Discussions
gcc's thread sanitizer reports a race condition in Intel MKL Pardiso
MBDyn-User
Dear Intel MKL developers,
I'm using Intel MKL Pardiso as a parallel direct linear solver for the multibody dynamics software MBDyn (https://public.gitlab.polimi.it/DAER/mbdyn). Pardiso provides significant performance improvements compared to all other solvers currently used with MBDyn. Unfortunately this solver suffers from stability issues which are not observed with Umfpack for example. If MBDyn is compiled with gcc's -fsanitize=thread, several warnings about race conditions in Pardiso are reported. Those warnings do not appear if Pardiso is used in single thread mode (e.g. if only one OpenMP thread is used). Since only a single thread in MBDyn is calling pardiso, I suppose that the race condition is caused by Pardiso itself.
Below you can find further information, how Pardiso is used by MBDyn:
The following links show the code which provides the interface between MBDyn and Pardiso:
https://public.gitlab.polimi.it/DAER/mbdyn/-/blob/develop/libraries/libmbwrap/pardisowrap.h
https://public.gitlab.polimi.it/DAER/mbdyn/-/blob/develop/libraries/libmbwrap/pardisowrap.cc
In order to build MBDyn on a Linux system (e.g. Ubuntu 20.04) with support for Pardiso use the following steps:
tar -jxvf mbdyn-pardiso.tar.bz2
./mbdyn-pardiso.sh
Then you should get a message like below. If you need further information, please let me know!
WARNING: ThreadSanitizer: data race (pid=257811)
Write of size 8 at 0x7b4000010000 by main thread:
#0 free ../../../../src/libsanitizer/tsan/tsan_interceptors_posix.cpp:707 (libtsan.so.0+0x35f25)
#1 mkl_serv_free_buffers <null> (libmkl_core.so+0x200334)
Previous write of size 8 at 0x7b4000010000 by thread T6:
#0 malloc ../../../../src/libsanitizer/tsan/tsan_interceptors_posix.cpp:651 (libtsan.so.0+0x30323)
#1 mm_account_ptr_by_tid..0 <null> (libmkl_core.so+0x1fe133)
Thread T6 (tid=257818, running) created by main thread at:
#0 pthread_create ../../../../src/libsanitizer/tsan/tsan_interceptors_posix.cpp:962 (libtsan.so.0+0x5ea79)
#1 <null> <null> (libgomp.so.1+0x1adea)
#2 PardisoSolutionManager<SpGradientSparseMatrixHandler, int>::Solve() mbdyn/libraries/libmbwrap/pardisowrap.cc:270 (mbdyn+0x11bfd04)
#3 LineSearchFull::Solve(NonlinearProblem const*, Solver*, int, double const&, int&, double&, double const&, double&) mbdyn/mbdyn/base/linesearch.cc:707 (mbdyn+0x76281c)
#4 DerivativeSolver::Advance(Solver*, double, double, StepIntegrator::StepChange, std::deque<MyVectorHandler*, std::allocator<MyVectorHandler*> >&, std::deque<MyVectorHandler*, std::allocator<MyVectorHandler*> >&, MyVectorHandler*, MyVectorHandler*, int&, double&, double&) mbdyn/mbdyn/base/stepsol.cc:310 (mbdyn+0x59786a)
#5 Solver::Prepare() mbdyn/mbdyn/base/solver.cc:839 (mbdyn+0x58a8bd)
#6 Solver::Run() mbdyn/mbdyn/base/solver.cc:1632 (mbdyn+0x56fab0)
#7 RunMBDyn mbdyn/mbdyn/mbdyn.cc:1498 (mbdyn+0x50c137)
#8 mbdyn_program mbdyn/mbdyn/mbdyn.cc:942 (mbdyn+0x50c137)
#9 main mbdyn/mbdyn/mbdyn.cc:1168 (mbdyn+0x4ec45b)
SUMMARY: ThreadSanitizer: data race (/lib/x86_64-linux-gnu/libmkl_core.so+0x200334) in mkl_serv_free_buffers
ThreadSanitizer: reported 1 warnings
Khang_N_Intel
Hi Reinhard,
I am glad that Pardiso is stable and , just like you mentioned, those issues might problably be false positive due to the fact that gcc doesn't like the code compiled by other compilers.
Anyway, I am going to close this thread. Should you discover other issues relating to oneMKL, please do not hesitate to let us know.
This thread will no longer be monitored.
Khang
VidyalathaB_Intel
>>race conditions in Pardiso are reported..warnings do not appear if Pardiso is used in single thread mode
You can avoid these race conditions by using mkl_set_num_threads_local function as this only affects the current execution thread of the application.
Please refer to the below link
https://software.intel.com/content/www/us/en/develop/documentation/onemkl-linux-developer-guide/top/managing-performance-and-memory/improving-performance-with-threading/avoiding-conflicts-in-the-execution-environment.html
You can get more details regarding the mkl_set_num_threads_local function from the below link.
https://software.intel.com/content/www/us/en/develop/documentation/onemkl-developer-reference-c/top/support-functions/threading-control/mkl-set-num-threads-local.html#mkl-set-num-threads-local
Hope the information provided above helps.
Vidya.
MBDyn-User
Dear Vidya,
Thank you for your advice, but it does not solve the issue. In this software there is only a single thread in the main program which is calling Pardiso. In addition to that, the race condition also appears if the main program uses only one thread of execution (e.g. no multithreading is used outside Pardiso). According to the link you shared, using mkl_set_num_threads_local should help only in situations where MKL is called from several threads simultaneously.
Best regards
MBDyn-User
VidyalathaB_Intel
We are looking into this issue, we will get back to you soon.
Vidya.
MBDyn-User
Dear Vidya,
Thank you for your support! It seems that unstable numerical factorization with pardiso (e.g. zero pivot) is not related to those race condition. Probably the issue was, that the weighted matching (e.g. phase=11) was not executed always when former non-zeros in the matrix pattern were turned to numerical zeros again. The reason for that is, that in MBDyn the non-zero pattern is preserved between iterations, unless new non-zeros appear. Only in the latter case the symbolic factorization (e.g. phase=11) was executed. So, the weighted matching was still based on an old non-zero pattern and zero pivots were the consequence. The new approach is to compute a checksum of the non-zero pattern, considering only numerical non-zeros. Whenever this checksum changes, the symbolic factorization is executed again. See pardisowrap.cc.  However, with this approach pardiso is no longer competitive in some cases because the numerical non-zero pattern changes almost at each iteration. Another alternative would be to compute the backward error of the solution. Whenever the backward error is above a certain limit or zero pivot (e.g. ierror = -4) is detected, the symbolic factorization is repeated. This approach is not fully tested yet.
Nevertheless, it would be fine if also those race condition could be fixed because it could lead to further issues.
Best regards
MBDyn-User
Khang_N_Intel
Thank you for the additional information!
We are currently working on the issue and will let you know how we will proceed next.
Khang
Khang_N_Intel
Hi Reinhard,
I have been trying to reproduce the issue that you mentioned with no success.
I received many errors when running the script mbdyn-pardiso.sh.
I tried it on 2 different systems.
I will do some troubleshooting and will let you know how thing goes.
Khang
Khang_N_Intel
Hi Reinhard,
I am still having problem with reproducing the error. Let me gather the error and will send it to you.
Best,
Khang
MBDyn-User
Dear Khang,
What kind of problems do you have? Were you able to compile and run the code?
MBDyn User
Khang_N_Intel
Hi Reinhard,
The issue is the same on both machines.
When I ran the shell script mbdyn-pardiso.sh, it complained that the bootstrap and configure are not found. Also, the permission is denied for mbdyn/mbdyn.
Khang
MBDyn-User
Dear Khang,
I think there was an issue in the first submission that the bootstrap script was called "bootstrap" instead of "bootstrap.sh". If bootstrap is not executed, "configure" and "mbdyn" will not be generated. I have attached a new version of all files.
On Ubuntu you probably need to install additional packages:
sudo apt-get build-dep octave
sudo apt-get install  libmkl-full-dev
Please let me know if you have still problems running the script!
Best regards
Reinhard
Khang_N_Intel
Hi Reinhard,
Thank you for providing the updated code!
I will test the new update and will you know the status.
Khang
Khang_N_Intel
Hi Reinhard,
I tried to reproduce the issue on the latest version of oneMKL, 2022.1, which came out not too long ago. However, I ran into multiple errors when running the script you mentioned.
At first, I got an error: aclocal: not found. In order to fix this error I had to install two additional packages as followed:
sudo apt-get install autotools-dev
sudo apt-get install automake
I then encountered more errors which I captured in the file error-running-mbdyn-pardiso.sh.txt.
Khang_N_Intel
I captured all the errors I encountered when running the script mbdyn-pardiso.sh.
Khang_N_Intel
Oops! forgot to print the output
$ ./mbdyn-pardiso.sh
Cloning into 'mbdyn'...
remote: Enumerating objects: 73214, done.
remote: Counting objects: 100% (859/859), done.
remote: Compressing objects: 100% (313/313), done.
remote: Total 73214 (delta 574), reused 814 (delta 545), pack-reused 72355
Receiving objects: 100% (73214/73214), 34.72 MiB | 7.32 MiB/s, done.
Resolving deltas: 100% (59048/59048), done.
+ aclocal
configure.ac:387: warning: macro 'AM_PROG_LIBTOOL' not found in library
acinclude.m4:37: warning: prefer named diversions
+ libtoolize --automake --force --copy
./bootstrap.sh: 6: libtoolize: not found
+ autoheader
+ automake --foreign --add-missing --copy --force-missing
configure.ac:311: installing 'build/compile'
configure.ac:111: installing 'build/config.guess'
configure.ac:111: installing 'build/config.sub'
configure.ac:113: installing 'build/install-sh'
configure.ac:113: installing 'build/missing'
libraries/libann/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libann/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libann/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libann/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libann/Makefile.am:6:  its definition is in aclocal's search path.
libraries/libann/Makefile.am: installing 'build/depcomp'
libraries/libcolamd/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libcolamd/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libcolamd/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libcolamd/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libcolamd/Makefile.am:6:  its definition is in aclocal's search path.
libraries/libmbc/Makefile.am:19: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libmbc/Makefile.am:19:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libmbc/Makefile.am:19:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libmbc/Makefile.am:19:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libmbc/Makefile.am:19:  its definition is in aclocal's search path.
libraries/libmbmath/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libmbmath/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libmbmath/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libmbmath/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libmbmath/Makefile.am:6:  its definition is in aclocal's search path.
libraries/libmbutil/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libmbutil/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libmbutil/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libmbutil/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libmbutil/Makefile.am:6:  its definition is in aclocal's search path.
libraries/libmbwrap/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libmbwrap/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libmbwrap/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libmbwrap/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libmbwrap/Makefile.am:6:  its definition is in aclocal's search path.
libraries/libnaive/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libnaive/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libnaive/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libnaive/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libnaive/Makefile.am:6:  its definition is in aclocal's search path.
libraries/libobjs/Makefile.am:5: error: Libtool library used but 'LIBTOOL' is undefined
libraries/libobjs/Makefile.am:5:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/libobjs/Makefile.am:5:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/libobjs/Makefile.am:5:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/libobjs/Makefile.am:5:  its definition is in aclocal's search path.
libraries/liby12/Makefile.am:5: error: Libtool library used but 'LIBTOOL' is undefined
libraries/liby12/Makefile.am:5:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
libraries/liby12/Makefile.am:5:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
libraries/liby12/Makefile.am:5:  If 'LT_INIT' is in 'configure.ac', make sure
libraries/liby12/Makefile.am:5:  its definition is in aclocal's search path.
mbdyn/aero/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
mbdyn/aero/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
mbdyn/aero/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
mbdyn/aero/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
mbdyn/aero/Makefile.am:6:  its definition is in aclocal's search path.
mbdyn/base/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
mbdyn/base/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
mbdyn/base/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
mbdyn/base/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
mbdyn/base/Makefile.am:6:  its definition is in aclocal's search path.
mbdyn/elec/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
mbdyn/elec/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
mbdyn/elec/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
mbdyn/elec/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
mbdyn/elec/Makefile.am:6:  its definition is in aclocal's search path.
mbdyn/hydr/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
mbdyn/hydr/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
mbdyn/hydr/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
mbdyn/hydr/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
mbdyn/hydr/Makefile.am:6:  its definition is in aclocal's search path.
mbdyn/struct/Makefile.am:6: error: Libtool library used but 'LIBTOOL' is undefined
mbdyn/struct/Makefile.am:6:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
mbdyn/struct/Makefile.am:6:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
mbdyn/struct/Makefile.am:6:  If 'LT_INIT' is in 'configure.ac', make sure
mbdyn/struct/Makefile.am:6:  its definition is in aclocal's search path.
mbdyn/thermo/Makefile.am:5: error: Libtool library used but 'LIBTOOL' is undefined
mbdyn/thermo/Makefile.am:5:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
mbdyn/thermo/Makefile.am:5:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
mbdyn/thermo/Makefile.am:5:  If 'LT_INIT' is in 'configure.ac', make sure
mbdyn/thermo/Makefile.am:5:  its definition is in aclocal's search path.
utils/Makefile.am:98: error: Libtool library used but 'LIBTOOL' is undefined
utils/Makefile.am:98:  The usual way to define 'LIBTOOL' is to add 'LT_INIT'
utils/Makefile.am:98:  to 'configure.ac' and run 'aclocal' and 'autoconf' again.
utils/Makefile.am:98:  If 'LT_INIT' is in 'configure.ac', make sure
utils/Makefile.am:98:  its definition is in aclocal's search path.
+ autoconf
configure.ac:387: error: possibly undefined macro: AM_PROG_LIBTOOL
   If this token and others are legitimate, please use m4_pattern_allow.
   See the Autoconf documentation.
+ test -d contrib
+ find contrib -name bootstrap.sh
+ echo contrib/n2m/bootstrap.sh
+ sed s/\(.*\)\/bootstrap\.sh/\1/
+ dir=contrib/n2m
+ pwd
+ olddir=/home/tce/Documents/2022/OLD-forum-05214468/mbdyn-pardiso/mbdyn
+ echo => entering subdir 'contrib/n2m'...
+ cd contrib/n2m
+ sh bootstrap.sh
+ aclocal
configure.ac:7: warning: macro 'AM_PROG_LIBTOOL' not found in library
bootstrap.sh: 5: libtoolize: not found
+ autoheader
configure.ac:6: installing './compile'
configure.ac:3: installing './config.guess'
configure.ac:3: installing './config.sub'
configure.ac:4: installing './install-sh'
configure.ac:4: installing './missing'
Makefile.am: installing './depcomp'
+ autoconf
configure.ac:7: error: possibly undefined macro: AM_PROG_LIBTOOL
+ echo <= leaving subdir 'contrib/n2m'; reverting to dir '/home/tce/Documents/2022/OLD-forum-05214468/mbdyn-pardiso/mbdyn'...
Configuring MBDyn Devel ...
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking configure arguments... checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for gfortran... gfortran
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran... -L/opt/intel/oneapi/vpl/2022.0.0/lib/../lib -L/opt/intel/oneapi/mpi/2021.5.0//libfabric/lib/../lib -L/opt/intel/oneapi/mpi/2021.5.0//lib/../lib -L/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib/../lib -L/opt/intel/oneapi/compiler/2022.0.1/linux/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/9 -L/usr/lib/gcc/x86_64-linux-gnu/9/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/9/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/opt/intel/oneapi/vpl/2022.0.0/lib -L/opt/intel/oneapi/tbb/2021.5.0/env/../lib/intel64/gcc4.8 -L/opt/intel/oneapi/mpi/2021.5.0//libfabric/lib -L/opt/intel/oneapi/mpi/2021.5.0//lib/release -L/opt/intel/oneapi/mpi/2021.5.0//lib -L/opt/intel/oneapi/mkl/2022.0.1/lib/intel64 -L/opt/intel/oneapi/ipp/2021.5.1/lib/intel64 -L/opt/intel/oneapi/ippcp/2021.5.0/lib/intel64 -L/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib -L/opt/intel/oneapi/dal/2021.5.1/lib/intel64 -L/opt/intel/oneapi/compiler/2022.0.1/linux/compiler/lib/intel64_lin -L/opt/intel/oneapi/compiler/2022.0.1/linux/lib -L/opt/intel/oneapi/clck/2021.5.0/lib/intel64 -L/opt/intel/oneapi/ccl/2021.5.0/lib/cpu_gpu_dpcpp -L/usr/lib/gcc/x86_64-linux-gnu/9/../../.. -lgfortran -lm -lquadmath
checking for dummy main to link with Fortran libraries... none
checking how to get verbose linking output from gfortran... (cached) -v
checking for Fortran libraries of gfortran... (cached) -L/opt/intel/oneapi/vpl/2022.0.0/lib/../lib -L/opt/intel/oneapi/mpi/2021.5.0//libfabric/lib/../lib -L/opt/intel/oneapi/mpi/2021.5.0//lib/../lib -L/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib/../lib -L/opt/intel/oneapi/compiler/2022.0.1/linux/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/9 -L/usr/lib/gcc/x86_64-linux-gnu/9/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/9/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/opt/intel/oneapi/vpl/2022.0.0/lib -L/opt/intel/oneapi/tbb/2021.5.0/env/../lib/intel64/gcc4.8 -L/opt/intel/oneapi/mpi/2021.5.0//libfabric/lib -L/opt/intel/oneapi/mpi/2021.5.0//lib/release -L/opt/intel/oneapi/mpi/2021.5.0//lib -L/opt/intel/oneapi/mkl/2022.0.1/lib/intel64 -L/opt/intel/oneapi/ipp/2021.5.1/lib/intel64 -L/opt/intel/oneapi/ippcp/2021.5.0/lib/intel64 -L/opt/intel/oneapi/dnnl/2022.0.1/cpu_dpcpp_gpu_dpcpp/lib -L/opt/intel/oneapi/dal/2021.5.1/lib/intel64 -L/opt/intel/oneapi/compiler/2022.0.1/linux/compiler/lib/intel64_lin -L/opt/intel/oneapi/compiler/2022.0.1/linux/lib -L/opt/intel/oneapi/clck/2021.5.0/lib/intel64 -L/opt/intel/oneapi/ccl/2021.5.0/lib/cpu_gpu_dpcpp -L/usr/lib/gcc/x86_64-linux-gnu/9/../../.. -lgfortran -lm -lquadmath
checking for g77... no
checking for xlf... no
checking for f77... f77
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether f77 accepts -g... yes
checking for gcc version = 3.3... no
checking for gcc version = 3.2... no
./configure: line 7893: AM_PROG_LIBTOOL: command not found
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking atomic_ops.h usability... no
checking atomic_ops.h presence... no
checking for atomic_ops.h... no
checking cxxabi.h usability... no
checking cxxabi.h presence... no
checking for cxxabi.h... no
checking fenv.h usability... yes
checking fenv.h presence... yes
checking for fenv.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking pwd.h usability... yes
checking pwd.h presence... yes
checking for pwd.h... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking semaphore.h usability... yes
checking semaphore.h presence... yes
checking for semaphore.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for stdint.h... (cached) yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking sys/pstat.h usability... no
checking sys/pstat.h presence... no
checking for sys/pstat.h... no
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/sysinfo.h usability... yes
checking sys/sysinfo.h presence... yes
checking for sys/sysinfo.h... yes
checking sys/times.h usability... yes
checking sys/times.h presence... yes
checking for sys/times.h... yes
checking for sys/types.h... (cached) yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking values.h usability... yes
checking values.h presence... yes
checking for values.h... yes
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking how to run the C++ preprocessor... g++ -E
checking exception usability... yes
checking exception presence... yes
checking for exception... yes
checking stdexcept usability... yes
checking stdexcept presence... yes
checking for stdexcept... yes
checking netcdf usability... no
checking netcdf presence... no
checking for netcdf... no
checking netcdfcpp.h usability... no
checking netcdfcpp.h presence... no
checking for netcdfcpp.h... no
checking netcdf.h usability... no
checking netcdf.h presence... no
checking for netcdf.h... no
checking udunits.h usability... no
checking udunits.h presence... no
checking for udunits.h... no
checking for _aligned_malloc and _aligned_free... no
checking for posix_memalign... yes
checking for memalign... yes
checking for aligned_alloc... yes
checking blitz/blitz.h usability... no
checking blitz/blitz.h presence... no
checking for blitz/blitz.h... no
checking blitz/array.h usability... no
checking blitz/array.h presence... no
checking for blitz/array.h... no
checking blitz/tinyvec.h usability... no
checking blitz/tinyvec.h presence... no
checking for blitz/tinyvec.h... no
checking blitz/tinyvec-et.h usability... no
checking blitz/tinyvec-et.h presence... no
checking for blitz/tinyvec-et.h... no
checking blitz/tinymat.h usability... no
checking blitz/tinymat.h presence... no
checking for blitz/tinymat.h... no
checking blitz/matrix.h usability... no
checking blitz/matrix.h presence... no
checking for blitz/matrix.h... no
checking for clock_nanosleep in -lrt... yes
checking for noexcept... yes
checking for offsetof... yes
checking for main in -lws2_32... no
checking for socket... yes
checking for socklen_t... yes
checking for sig_atomic_t... yes
checking whether bool is defined... yes
checking whether the C++ compiler handles exceptions... yes
checking whether the C++ compiler allows to use namespace std... yes
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for PTHREAD_PRIO_INHERIT... yes
checking for threads... yes
checking for usable pthread_setaffinity_np... yes
checking for usable pthread_sigmask... yes
checking ltdl.h usability... no
checking ltdl.h presence... no
checking for ltdl.h... no
configure: WARNING: no dynamic linking capability detected; runtime loading disabled
checking whether to enable multithread... configure: error: need atomic_ops.h (from HP's atomic_ops project)
make: *** No targets specified and no makefile found. Stop.
./mbdyn-pardiso.sh: 19: mbdyn/mbdyn/mbdyn: not found
MBDyn-User
OK, it seems that there are still missing packages.
Please try to install the following packages and then run the script again!
sudo apt-get install libatomic-ops-dev
Khang_N_Intel
Hi Reinhard,
I tried to install the 2 packages you mentioned. The first one went fine. However, it gave me an error when executing the second one:
E: Invalid operation build-dev
I tried to just install octave:
sudo apt-get install octave
I then reran the scipt file. However, I still received the same error as I mentioned in my last post.
MBDyn-User
Dear Khang,
The command is
not
sudo apt-get build-dev octave
As an alternative you could also use
sudo apt-get install automake autoconf libtool
in order to install missing libtoolize which was missing when you run bootstrap.
Probably you also need
in order to use pardiso.
Best regards
Reinhard
Khang_N_Intel
Hi Reinhard,
Thank you for the info. I finally was able to finish running the script, although I couldn't use thecommand:
sudo apt-get build-dep octacve
I had to use the alternative that you also provided.
I also replaced the version of mkl that you provided with the latest version of oneMKL, 2022.0.
The data race issue still exists in oneMKl 2022.0
I will send the issue to the mkl developer team to further inverstigate.
Khang
Khang_N_Intel
Hi Reinhard,
After testing the reproducer the engineer suspected that the warning errors:
WARNING: ThreadSanitizer: data race...
could be false positive.
They would like: to have a reproducer of Pardiso stability issue and the expected behavior so that they can locate locate the cause and to verify if the problem is fixed.
Khang
MBDyn-User
Dear Khang,
Since I posted this issue, a lot of changes were applied to the code base of MBDyn. Actually I think that the Pardiso solver is stable and does not suffer from stability issues. Indeed gcc's thread sanitizer might report false positives if code which was not  compiled with gcc's -fsanitize=thread option performs atomic variable access. Such access cannot be intercepted by the thread sanitizer and could lead to those false positives .
Nevertheless, I can run the MBDyn/Pardiso solver through a test suite of more than 400 tests in multi-thread mode if you want. In case of a failure in one of those tests, I would provide the files to reproduce that test.
