7302 Discussions
lapack double complex test suite seg faults with mkl 9.1 and gfortran
celismr
I am running the lapack 3.1 test suite for double complex on a SLES10 system using gfortran compilers. I am using
% gfortran -L(MKL_PATH) -lmkl_gfortran -lmkl_lapack -lguide -lpthreads
when linking mkl.
The program xlintstz gives a segmentation fault. Using gdb I can see it occurs in zdotc_.
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 47446249872096 (LWP 22378)]
0x00002b26f148cd9a in IncAny_Loop4 () from /opt/intel/mkl/9.1.023/lib/em64t/libmkl_p4n.so
(gdb) where
#0 0x00002b26f148cd9a in IncAny_Loop4 () from /opt/intel/mkl/9.1.023/lib/em64t/libmkl_p4n.so
#1 0x00007fffbb188e88 in ?? ()
#2 0x00007fffbb189030 in ?? ()
#3 0x0000000009492f20 in a.945 ()
#4 0x00007fffbb189030 in ?? ()
#5 0x00007fffbb188e88 in ?? ()
#6 0x00002b26f1489b4e in zdotc_ () from /opt/intel/mkl/9.1.023/lib/em64t/libmkl_p4n.so
#7 0x00002b26efa3400e in w_zdotc () from /opt/intel/mkl/9.1.023/lib/em64t/libmkl_gfortran.so
#8 0x00002b26efa34132 in zdotc_ () from /opt/intel/mkl/9.1.023/lib/em64t/libmkl_gfortran.so
#9 0x0000000000000000 in ?? ()
Is this the proper way to use mkl and gfortran?
Thank you
Mimi Celis
